[mapserver-users] SV: Clipping out unprojectable area?
Ben Madin
ben at remoteinformation.com.au
Fri May 29 00:04:31 EDT 2009
Pâl,
On 28/05/2009, at 9:38 PM, paalkr wrote:
> Does anyone have a clue regarding what I have to do, to sort out
> this issue?
there is a clue in the log file :
> [Mon May 25 14:03:08 2009].187807 msPostGISLayerWhichShapes(): Query
> error. Error (ERROR: argument of WHERE must be type boolean, not type
> geometry
but if you look at your query in the log file (trying to make it look
a bit nice for legibility) :
> FROM (
> SELECT geometri, *
> FROM general.country
> WHERE ST_Intersection(geometri,GeomFromText('POLYGON((12 0,18 0,18
> 84,12 84,120))',4326))
> ) AS country
You have a WHERE clause that returns a geometry (here is the manual
entry)
ST_Intersection(geometry, geometry) Returns a geometry that
represents the point set intersection of the Geometries.
In other words - that portion of geometry A and geometry B that is
shared between the two geometries.
So you need to actually compare something with the geometry to make
the where clause work.
I hope this helps to steer you in the right direction... I have no
idea what you are trying to compare!
Ben
> paalkr wrote:
>> Hi, thanks for the help!
>> I tried your suggestion, but I didn't manage to get it to work
>> correctly,
>> this is what I did:
>> Entered the following DATA statement:
>> DATA "geometri from ( select geometri, * from general.country where
>> ST_Intersection(geometri,GeomFromText('POLYGON((12 0,18 0,18 84,12
>> 84,12
>> 0))',4326)) ) AS country USING UNIQUE ogc_fid USING SRID=4326"
>> but I then got the following error in the MapServer logfile:
>> [Mon May 25 14:03:08 2009].185400 msPostGISLayerWhichShapes query:
>> select
>> encode
>> (AsBinary(force_collection(force_2d("geometri")),'NDR'),'base64') as
>> geom,"ogc_fid" from ( select geometri, * from general.country where
>> 84,12
>> 0))',4326)) ) AS country where geometri &&
>> GeomFromText('POLYGON((-5.89995617157446
>> 59.7658748898858,-5.89995617157446 75.1604740311875,44.7675433183202
>> 75.1604740311875,44.7675433183202 59.7658748898858,-5.89995617157446
>> 59.7658748898858))',4326)
>> [Mon May 25 14:03:08 2009].187786 msPostGISLayerWhichShapes query
>> status:
>> 7
>> type
>> geometry
>> Anyone that can help with this?
>> Regards,
>> Pål Kristensen
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome WA 6725
Out here, it pays to know...
