[mapserver-users] Re: Upgrading 5.2 -> 5.4 generating CGI error on
IIS(5.1 and 6.0) ... Possible BUG?
Paul james
pauljame at gmail.com
Fri May 29 11:07:57 EDT 2009
Just some more information about the problem...
The error was generated by IIS (5.1 and 6.0) ... Looking the Logfile, It is
a 502 error :
*502* - Web server received an invalid response while acting as a gateway or
proxy.
*502.1* - CGI application timeout.
*502.2* - Error in CGI application.
It only happens with Mapserver 5.4 ... With 5.2 version, thats 100%
working...
Paul
On Thu, May 28, 2009 at 5:43 PM, Paul james <pauljame at gmail.com> wrote:
> I got that error when try to enter :
> http://localhost/cgi-bin/mapserv.exe?map=C:/map.map
> CGI ErrorThe specified CGI application misbehaved by not returning a
> complete set of HTTP headers. The headers it did return are:
> My Map:
> MAP
> EXTENT -79.7892 -34.2426 -24.9958 6.11775
> FONTSET "Fonts\Fonts.txt"
> IMAGECOLOR 230 254 254
> IMAGETYPE png
> SIZE 800 600
> STATUS ON
> UNITS dd
> NAME "Test"
> OUTPUTFORMAT
> NAME "png"
> MIMETYPE "image/png"
> DRIVER "GD/PNG"
> EXTENSION "png"
> IMAGEMODE "PC256"
> TRANSPARENT FALSE
> END
> PROJECTION
> 'proj=longlat'
> 'ellps=WGS84'
> 'datum=WGS84'
> 'no_defs'
> END
> WEB
> IMAGEPATH 'C:\map\temp'
> IMAGEURL '/tmp/'
> QUERYFORMAT text/html
> LEGENDFORMAT text/html
> BROWSEFORMAT text/html
> END
> QUERYMAP
> COLOR 255 0 0
> SIZE -1 -1
> STATUS ON
> STYLE hilite
> END
> REFERENCE
> STATUS on
> SIZE 221 150
> MINBOXSIZE 5
> MAXBOXSIZE 150
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
> MARKERSIZE 8
> END
> LAYER
> NAME Test
> GROUP "Tests"
> TYPE POLYGON
> STATUS default
> CONNECTIONTYPE POSTGIS
> CONNECTION "user=xpassword=xdbname=x host=x port=5432"
> DATA "the_geom from viwgeo_x USING UNIQUE oid USING SRID=-1"
> CLASS
> COLOR 255 0 255
> END
> END
> END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090529/42b9aac7/attachment-0001.html
