[mapserver-users] Re: Upgrading 5.2 -> 5.4 generating CGI error
on IIS(5.1 and 6.0) ... Possible BUG?
Paul james
pauljame at gmail.com
Fri May 29 11:40:28 EDT 2009
Hi Daniel...
I got the binaries from Tamas build :
http://vbkto.dyndns.org:1280/sdk/Default.aspx
And from MS4W 3.0 beta2...
Same result with both...
That error you got is my fault... I took off the :
IMAGE "..\Map.png"
from REFERENCE definition when copy the code to email...
My application works fine with 5.2 binary in iis 5.1 and 6.0
Just replacing with 5.4 binary I got that 502 error...
Paul
On Fri, May 29, 2009 at 12:20 PM, Daniel Morissette <
dmorissette at mapgears.com> wrote:
> Paul james wrote:
>> Just some more information about the problem...
>> The error was generated by IIS (5.1 and 6.0) ... Looking the Logfile, It
>> is a 502 error :
>> *502* - Web server received an invalid response while acting as a gateway
>> or proxy.
>> *502.1* - CGI application timeout.
>> *502.2* - Error in CGI application.
>> It only happens with Mapserver 5.4 ... With 5.2 version, thats 100%
>> working...
> Where did you get your binaries? Are you using MS4W?
> This may be a sign of a problem with your build or bug in MapServer, but
> we'd need a testcase to reproduce it in order to help. I tried just loading
> your mapfile and get the following error:
> loadReferenceMap(): General error message. No image defined for the
> reference map.
> I don't know if that's an indication of the problem, but anyway, if the 502
> error persists you could try to package a small testcase (mapfile + data +
> test url) that can be used to reproduce the issue and file a ticket.
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090529/fad7ef69/attachment.html
