[mapserver-users] Re: Upgrading 5.2 -> 5.4 generating CGI error on IIS(5.1 and 6.0) ... Possible BUG?
Tamas Szekeres szekerest at gmail.com
Fri May 29 13:27:14 EDT 2009
Hi Paul,
Did you experience the same with the release-1310 and release-1400 versions?
Did you experience the same with the development version?
Are you using fastCGI or normal cgi?
Is this just a PostGIS related problem or you get the same with a simple
shapefile?
Sorry for the bunch of the questions...
Best regards,
Tamas
2009/5/29 Paul james <pauljame at gmail.com>
> Yes Daniel...  I deleted all previous files and put only 5.4 files... My
> mapscript application is working fine on 5.4...
> But the CGI dont...
> Tested on Windows XP (IIS 5.1) and Windows 2003(IIS 6.0)...
> Paul
> On Fri, May 29, 2009 at 12:56 PM, Daniel Morissette <
> dmorissette at mapgears.com> wrote:
>> Paul james wrote:
>>> Hi Daniel...
>>> I got the binaries from Tamas build :
>>> http://vbkto.dyndns.org:1280/sdk/Default.aspx
>>> And from MS4W 3.0 beta2...
>>> Same result with both...
>>> That error you got is my fault... I took off the :
>>> IMAGE "..\Map.png"
>>> from REFERENCE definition when copy the code to email...
>>> My application works fine with 5.2 binary in iis 5.1 and 6.0
>>> Just replacing with 5.4 binary I got that 502 error...
>> Hopefully you always make sure you update all DLLs as well when you
>> "replace with 5.4 binary"? Even if the DLLs have the same names, if they
>> come from different build environments or versions they may not be
>> compatible and could cause the kind of crashes that you are experiencing.
>> Daniel
>> Daniel Morissette
>> http://www.mapgears.com/
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090529/fdb8e2e9/attachment.html
