[mapserver-users] Place names...?
James Leveille James_Leveille at dmr.ca
Fri May 29 13:52:52 EDT 2009
Hi Chris,
In order to help us help you, give us an overview of you code ...
It should work fine with POINT.
Here is a working example :
  LAYER
    NAME                  "pd_p_bldg"
    STATUS                ON
    DUMP                  TRUE
    PROJECTION
    END
    METADATA
    END
    EXTENT                3000000 0 10000000 5000000
    DATA                  "pd_p/subset_pd_p"
    TYPE                  POINT
    LABELITEM             "bldg_label"
    CLASS
      STYLE
        SYMBOL            "single_building"
      END
      LABEL
        TYPE              TRUETYPE
        FONT              "times-bold"
        SIZE              11
        POSITION          AUTO
        COLOR             227 119 0
        OUTLINECOLOR      250 250 250
        PARTIALS          FALSE
      END
    END
  END
________________________________________________________________________
James
De : mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] De la part de Chris Green
Envoyé : 29 mai 2009 13:42
À : mapserver-users at lists.osgeo.org
Objet : [mapserver-users] Place names...?
Hi all
Apologies in advance if this turns out to be a stupid question, but I can't find a way to make Map Server  v5.0 display place names. I have created a shape file with points for towns and cities, each of which has a label. If I check this layer with Quantum GIS (which I used to create the points) I can display both the points and the labels showing town and city names. However when I define this layer in the mapfile with type 'point' MapServer gives me a display of the points but not the labels.  If I define it as type 'annotation' I don't see either points or labels. I feel sure I am missing something obvious but after quite a few hours I am stuck.  Can anyone suggest what I am doing wrong?
Chris Green
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090529/ea90edfc/attachment.html
