[mapserver-users] Re: Upgrading 5.2 -> 5.4 generating CGI error on IIS(5.1 and 6.0) ... Possible BUG?
Brian Fischer bfischer at houstoneng.com
Sat May 30 22:56:05 EDT 2009
Paul,
Just to let you know you are not alone.  I am experiencing the same problem with MS4W 3.0 beta 1 and 2.  I’ve reported it as a bug to the MS4W project.  Here’s a link to the bug report http://bugzilla.maptools.org/show_bug.cgi?id=2043.   I haven’t heard anything back on a solution yet.  I’m not sure if this is a MapServer bug or a bug with the way the MS4W package was compiled.  It runs fine of Apache for me.
Brian Fischer
Houston Engineering, Inc.
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Paul james
Sent: Friday, May 29, 2009 1:08 PM
To: Steve Lime
Cc: mapserver-users at lists.osgeo.org; Daniel Morissette
Subject: Re: [mapserver-users] Re: Upgrading 5.2 -> 5.4 generating CGI error on IIS(5.1 and 6.0) ... Possible BUG?
http://localhost/cgi-bin/mapserv.exe?map=C%3A%2Finetpub%2Fwwwroot%2FOpenlayer%2FFiles%2FMapserver%2FMap.map&mode=map&map_imagetype=png&mapext=-180+0+-90+90&imgext=-180+0+-90+90&map_size=256+256&imgx=128&imgy=128&imgxy=256+256
Paul
On Fri, May 29, 2009 at 3:01 PM, Steve Lime <Steve.Lime at dnr.state.mn.us<mailto:Steve.Lime at dnr.state.mn.us>> wrote:
What's the full URL submitted against the CGI?
>>> On 5/29/2009 at 12:59 PM, in message
<33fad6880905291059i5602a89q84d7673ddcfff511 at mail.gmail.com<mailto:33fad6880905291059i5602a89q84d7673ddcfff511 at mail.gmail.com>>, Paul
james
<pauljame at gmail.com<mailto:pauljame at gmail.com>> wrote:
> 1 -  I tried with 1500,1400,1310,development version(1500) and ms4w
beta...
> 2 -  Ím using normal CGI
> 3 - My tests are only with Postgis... Íll generate a shapefile to
test
> later ...
> Paul
> On Fri, May 29, 2009 at 2:27 PM, Tamas Szekeres <szekerest at gmail.com<mailto:szekerest at gmail.com>>
wrote:
>> Hi Paul,
>> Did you experience the same with the release-1310 and release-1400
>> versions? Did you experience the same with the development version?
>> Are you using fastCGI or normal cgi?
>> Is this just a PostGIS related problem or you get the same with a
simple
>> shapefile?
>> Sorry for the bunch of the questions...
>> Best regards,
>> Tamas
>> 2009/5/29 Paul james <pauljame at gmail.com<mailto:pauljame at gmail.com>>
>>> Yes Daniel...  I deleted all previous files and put only 5.4
files... My
>>> mapscript application is working fine on 5.4...
>>> But the CGI dont...
>>> Tested on Windows XP (IIS 5.1) and Windows 2003(IIS 6.0)...
>>> Paul
>>> On Fri, May 29, 2009 at 12:56 PM, Daniel Morissette <
>>> dmorissette at mapgears.com<mailto:dmorissette at mapgears.com>> wrote:
>>>> Paul james wrote:
>>>>> Hi Daniel...
>>>>> I got the binaries from Tamas build :
>>>>> http://vbkto.dyndns.org:1280/sdk/Default.aspx
>>>>> And from MS4W 3.0 beta2...
>>>>> Same result with both...
>>>>> That error you got is my fault... I took off the :
>>>>> IMAGE "..\Map.png"
>>>>> from REFERENCE definition when copy the code to email...
>>>>> My application works fine with 5.2 binary in iis 5.1 and 6.0
>>>>> Just replacing with 5.4 binary I got that 502 error...
>>>> Hopefully you always make sure you update all DLLs as well when
you
>>>> "replace with 5.4 binary"? Even if the DLLs have the same names,
if they
>>>> come from different build environments or versions they may not
be
>>>> compatible and could cause the kind of crashes that you are
experiencing.
>>>> Daniel
>>>> Daniel Morissette
>>>> http://www.mapgears.com/
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090530/771489ce/attachment.html
