[mapserver-users] Re: MS4W Beta 7 -- Python-Mapscript-- queryByRect strange behavior
Steve Lime Steve.Lime at dnr.state.mn.us
Tue Nov 10 17:51:18 EST 2009
Actually I flipped the args to be more sensible since most folks don't use tiles. The signature
  int resultsGetShape( shapeObj shape, int shapeindex, int tileindex=-1)
I'm hoping getShape() won't see much use with 5.6 and we can flip the args in getShape too. (Dan,
perhaps I should add a resultsGetFeature() as well to match the getFeature() method?
>>> On 11/10/2009 at 4:13 PM, in message <4AF9E5A6.7030607 at mapgears.com>, Daniel
Morissette <dmorissette at mapgears.com> wrote:
> Christian Jauvin wrote:
>> Now I really tried to figure how to upgrade my < 5.6 code with the new
>> query mechanism that you added in 5.6, but (1) I couldn't find enough
>> documentation/example about the issue (I understand it is pretty new)
>> and (2) couldn't make enough sense of what I read in the MS 5.6 C
>> source that I downloaded. I cannot even figure out the exact arguments
>> to the method (as they are not explictly stated in the SWIG generated
>> code).
> I do not have an example just now, but the arguments to
> resultsGetShape() should be the same as for the older getShape() method.
> In the SWIG versions of MapScript:
> int resultsGetShape( shapeObj shape, int tileindex, int shapeindex )
> (See also http://mapserver.org/mapscript/mapscript.html#mapscript-classes)
