[mapserver-users] TOLERANCE
Ted Spradley tspradley at snoogems.com
Mon Nov 23 16:30:25 EST 2009
Hi all,
Simplifying from earlier.
1. Does TOLERANCE apply to polygons (layers)?
    The documentation says it only applies to points, but I am finding
postings referring to it applying to
    line and polygon features.
If yes to #1,
2. Using mode = itemfeaturequery to find a polygon in slayer=LAYER A, then
qlayer=LAYER B, finding the
     polygons with in TOLERANCE of the polygon in LAYER A.
   Does TOLERANCE get set in LAYER A or LAYER B? (tried it both ways and it
doesn't seem to matter)
Thanks in advance,
Ted S
Here is the MAP file
MAP
	NAME	"urlCountyApraisalDistricts"			#	WMS Capabilities requires a Name and
a Title tag for every
						#	layer. The Map’s NAME and wms_title metadata will be used
						#	to set the root layer’s name and title in the
						#	GetCapabilities XML output. The root layer in the WMS
						#	context corresponds to the whole mapfile
	SIZE            800 800
  EXTENT          -125 24 -65 50
	UNITS			DD
	IMAGECOLOR			100 100 255
  PROJECTION
    "init=epsg:4326"
  END
  IMAGETYPE PNG24
	SHAPEPATH	'/var/www/vhosts/url.com/subdomains/maps/mapserver/data/'
	STATUS	ON
  SYMBOLSET       "/usr/mapserver/mapserver-5.4.1/symbols/examples.sym"
  FONTSET         '/usr/share/fonts/fonts.list'
  CONFIG          "MS_ERRORFILE"
"/var/www/vhosts/url.com/subdomains/maps/mapserver/logs/cad1.log"
  WEB
   	TEMPLATE        "mapserver.html"
   	IMAGEPATH       "/var/www/vhosts/url.com/subdomains/maps/httpdocs/temp/"
    IMAGEURL        "/temp/"
    METADATA
     	"wms_title" "url WMS County Detail"
			"wfs_title"	"url WFS County Detail"
      "wms_srs" "EPSG:4326"
      "wfs_srs" "EPSG:4326"
			"wms_onlineresource"
"http://maps.url.com/cgi-bin/mapserv?map=/var/www/vhosts/url.com/subdomains/maps/httpdocs/mapserver/my_tests/county_cads&"
			"wfs_onlineresource"
        END
	END
  QUERYMAP
    STATUS ON
    STYLE hilite
    COLOR 212 212 212
  END
  OUTPUTFORMAT
    NAME 'selected_parcel'
    DRIVER 'TEMPLATE'
    MIMETYPE 'text/html'
    FORMATOPTION 'FILE=selected_parcel.tmpl'
  END
  SCALEBAR
    STATUS  embed
    INTERVALS 5
    ALIGN left
    POSITION lr
    SIZE 600 8
#    UNITS feet
    COLOR 0 0 0
    BACKGROUNDCOLOR 212 212 212
  END   # End Scalebar
  # Layer 'parcels' will draw individual property parcels and provide owner
data
  LAYER
    NAME 'parcels'
    TYPE POLYGON
    STATUS          DEFAULT
    DEBUG			3
    TEMPLATE        'dummy'
    DUMP TRUE
    MAXSCALEDENOM 7000
    CONNECTIONTYPE POSTGIS
    CONNECTION "dbname=cad1 user=user password=password host=localhost
port=5432"
    DATA            "the_geom from parcels using unique gid using srid=-1"
    LABELITEM "owner_name"
  #  FILTERITEM objectid
    FILTER (objectid == "%objectid%")
    PROCESSING 'LABEL_NO_CLIP=1'
#    TOLERANCEUNITS FEET
#    TOLERANCE 300
    CLASS
#			SYMBOL 'circle'
#			SIZE 2
#      OUTLINECOLOR 212 212 212
      STYLE
        WIDTH 1
        OUTLINECOLOR 0 255 0
      END
      LABEL
        COLOR 0 0 0
        #OUTLINECOLOR 0 255 0
        TYPE TRUETYPE
        FONT ARIAL
        SIZE 10
        BUFFER 5
        MINFEATURESIZE 20
     #   PARTIALS FALSE
        POSITION AUTO
        ANGLE AUTO
      END
    END   # End class
    PROJECTION
      "init=epsg:2278"
    END
    METADATA
      "wms_title" "County Property Parcels"
      "wfs_title" "County Property Parcels"
      "wms_srs"	"epsg:102740"
      "gml_include_items" "all"
      "gml_featureid" "ogc_fid" ## REQUIRED
      "qstring_validation_pattern" '.'
    END
  END # End layer 'parcels'
  # This layer to compare geometries with previous
  LAYER
    NAME 'parcels_01'
    TYPE POLYGON
    STATUS          ON
    DEBUG			3
    TEMPLATE        'dummy'
    DUMP TRUE
    MAXSCALEDENOM 7000
port=5432"
    # FILTER - valid SQL WHERE clause
    TOLERANCEUNITS feet
    TOLERANCE 300
    CLASS
#			SYMBOL 'circle'
#			SIZE 2
      STYLE
        WIDTH 2
        COLOR 139 136 120
      END
      LABEL
        COLOR 0 0 0
        TYPE TRUETYPE
        FONT ARIAL
        SIZE 10
        MINFEATURESIZE 20
     #   PARTIALS FALSE
        POSITION AUTO
        ANGLE AUTO
      END
    END   # End class
    PROJECTION
      "init=epsg:2278"
    END
    METADATA
      "wms_title" "County Property Parcels Comparison Layer"
      "wfs_title" "County Property Parcels Comparison Layer"
    END
  END # End layer 'parcels_01'
END # End map
View this message in context: http://n2.nabble.com/TOLERANCE-tp4054120p4054120.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
