[mapserver-users] Map from .OSM
Stephen Woodbridge woodbri at swoodbridge.com
Thu Nov 26 10:23:33 EST 2009
I believe GDAL/OGR (newer versions) has support for SpatialLite.
-Steve W
Rahkonen Jukka wrote:
> Hi,
> Igor Brejc wrote interesting news today on osm-users mailing list: "
> I've implemented importing of OSM data into SpatiaLite DB and
> integrated it successfully with Kosmos map rendering code. SpatiaLite
> OSM database can be quite fast, but I had to learn a trick or two to
> reach good performance. I even managed to import the latest UK data
> into it and it didn't complain too much. I'm planning to release this
> in Kosmos v3, hopefully sometimes in the spring of 2010."
> So there should be a SpatiaLite import utility available in the near
> future.  Next question is if Mapserver can render effectively from
> SpatiaLite.
> -Jukka Rahkonen-
>> -----Alkuperäinen viesti----- Lähettäjä:
>> mapserver-users-bounces at lists.osgeo.org
>> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Milo van
>> der Linden Lähetetty: 26. marraskuuta 2009 8:19 Vastaanottaja: abul
>> khayer Kopio: mapserver-users at lists.osgeo.org Aihe: Re:
>> Mapserver cannot read osm directly. That is also because there is
>> no OGR adapter(yet) for .osm.
>> If you really don't want to set up postgis:
>> http://wiki.openstreetmap.org/wiki/Category:OSM_processing
>> You can browse throug a variety of export/conversion tools. One
>> might just create the format you need (shp). You can also consider
>> downloading ready-made shapefiles from the websites:
>> http://www.cloudmade.com
>> or
>> http://www.geofabrik.de
>> Kind regards,
>> Milo van der Linden (Miblon) Moblin powered asus eee pc 1005HA-H
>> http://www.dogodigi.net
>> On Wed, 2009-11-25 at 19:01 -0800, abul khayer wrote:
>>> Can Mapserver render map from .OSM(Open street map) file
>>> directly?
>>> I want to use mapserserver and Openlayer to render a map of .OSM.
>>>  Though i get some help from below tutorial,
>>> http://trac.osgeo.org/mapserver/wiki/RenderingOsmData But it use
>>> postgis and there need conversion.
>>> ....................................... Md. Abul Khayer GIS
>>> Programmer CEGIS (www.cegisbd.com) Cell: +8801730019572 Blog:
>>> khayer.wordpress.com
>>> _______________________________________________ mapserver-users
>>> mailing list mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
