[mapserver-users] Can you pass draw scale into postgis SQL?
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Oct 3 22:13:50 EDT 2009
Open an enhancement request for this. If anyone has any additional
thoughts on this please add them to the ticket.
Thanks,
-Steve
Stephen Woodbridge wrote:
> Hi all,
> I would like to be able to make my postgis queries in mapserver be aware
> of the current draw scale. Is there an easy way to do this in the
> mapfile? I would like to avoid parameter substitution since mapserver is
> already aware of the scale, it would be nice if we could just embed a
> token like [scale] in a mapserver data statement and mapserver would
> substitute that for the current draw scale.
> DATA "way from (
> select way, osm_id, landuse, name
> from osm_landuse1 where landuse is not null
> and is_large_enough(area(way),'landuse1',[scale])
> ) as foo using unique osm_id using srid=900913"
> The idea here is that is_large_enough(area(way),'landuse1',[scale])
> whould return true or false based on comparing area(way) to some value
> it looks up for 'landuse1' and the current [scale]. This would allow
> dynamic filtering of data in the database based on the current scale.
> Likewise you could use the [scale] in a SQL case statement to
> dynamically change the SQL results based on scale.
> It would seem that this could greatly simplify mapfiles.
> -Steve W
> mapserver-users at lists.osgeo.org
