[mapserver-users] GetFeatureInfo
Iratxe Lejarreta
iratxe.lejarreta at axios.es
Tue Oct 6 07:26:32 EDT 2009
On Monday 05 October 2009 09:26:35 pm Rahkonen Jukka wrote:
> Hi,
> X and y in GetFeatureInfo request are image pixel coordinates, not
> geographic ones. See how ESRI describes it
> http://webhelp.esri.com/arcims/9.2/general/mergedProjects/wms_connect/wms_c
>onnector/get_featureinfo.htm
> -Jukka Rahkonen-
> Iratxe Lejarreta wrote:
> Hi,
> When I execute the following command, Postfix return the correct result:
> select * from building where
> ST_INTERSECTS(geom,'SRID=23030;POINT(579389.40625 4795144.78125)');
> But when I execute GetFeatureInfo request in MapServer with the same
> point(x,y), the response doesn't return any result:
> http://localhost/cgi-
bin/test?&SERVICE=wms&VERSION=1.1.1&REQUEST=getfeatureinfo&LAYERS=mylayer&Q
>UERY_LAYERS=mylayer&x=579389.40625&y=479511.78125&INFO_FORMAT=text/html&SRS=
>EPSG:23030&BBOX=532666.0,4749720.0,603151.0,4805350.0&WIDTH=512&HEIGHT=512
> My map file:
> MAP
> NAME "TEST"
> STATUS ON
> SIZE 400 300
> SYMBOLSET symbols.sym
> EXTENT 530000 4740000 610000 4820000
> UNITS METERS
> SHAPEPATH "data"
> IMAGECOLOR 255 255 255
> FONTSET fonts.txt
> WEB
> IMAGEPATH "/tmp/"
> IMAGEURL "/tmp/"
> HEADER "../templates/test_header.html"
> FOOTER "../templates/test_footer.html"
> METADATA
> "wms_title" "Test"
> "wms_onlineresource" "http://localhost/cgi-bin/test?"
> "wms_srs" "EPSG:23030"
> "wms_feature_info_mime_type" "text/html"
> END
> END
> PROJECTION
> "init=epsg:23030"
> END
> LAYER
> NAME mylayer
> PROJECTION
> "init=epsg:23030"
> END
> TYPE POLYGON
> STATUS ON
> DUMP TRUE
> UNITS METERS
> TEMPLATE "../templates/mylayer_body.html"
> CONNECTIONTYPE postgis
> CONNECTION "host=localhost port=5432 dbname=mydb user=postgres
> password=******"
> DATA "the_geom from mylayer"
> METADATA
> "wms_title" "mylayer"
> "wms_extent" "532666 4749720 603151 4805350"
> "wms_include_items" "all"
> END
> TOLERANCE 5
> CLASS
> NAME "building"
> STYLE
> COLOR 200 255 0
> OUTLINECOLOR 120 120 120
> END
> END
> END
> END
> I tried the same map configuration with another layer but with SRS:4326 and
> the result of GetFeatureInfo request is ok.
> If the difference is the projection and extent, where is the error?
> Thanks in advance!
Ok, I changed X and Y but the result is null.
The same request with shapefile gives me the result that I want, but with
postgis I don't receive any result.
Is there any bug with MapServer and Postgis in a different projection than
4326?
Thanks!
Iratxe Lejarreta
www.axios.es
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091006/21000be3/attachment.html
