[mapserver-users] maploading problem
sunny74
sb.ray at hotmail.com
Tue Oct 6 08:12:26 EDT 2009
Dear Friends,
The map from a mapserver takes enormously long time to load about 5 mins
when the server machine on which it works is set to accept public IP i.e
uses DHCP.
Most of the time it does not load at all - only a pink background is seen in
place of the map.
After changing a machine IP to public I also change the httpd file in conf
folder of Apache to
localhost:8085.
But despite this the above problem occurs.
Can someone tell me the cause of the problem and how to resolve?
Whether it can be solved by implementing mapfish?
Thanks for your responses.
View this message in context: http://n2.nabble.com/maploading-problem-tp3774596p3774596.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
