[mapserver-users] Call layer
jbloc1878 at googlemail.com
Tue Oct 6 12:22:34 EDT 2009
Yeah I have the same Projection in my map file.
PROJECTION
"proj=longlat"
"ellps=WGS84"
"datum=WGS84"
"no_defs"
END
Thanks for the response. It's pretty fustrating there must be another
simple method to call the layer
On 6 Oct 2009, at 13:37, Daniel Walton <dgwalton at gmail.com> wrote:
> I have this same problem, only I am using a Silverlight client to
> view the layers. I can view layers only by setting their status to
> DEFAULT. Whenever I request a layer whose status is ON, I get the
> response:
> Invalid CRS given : CRS must be valid for all requested layers.
> The CRS query string I passed is:
> &CRS=EPSG:4326
> The projection in my mapfile both for the whole map and individual
> layers is:
> PROJECTION
> "proj=longlat"
> "ellps=WGS84"
> "datum=WGS84"
> "no_defs"
> END
> It looks like the problem is in referencing the EPSG file, and I
> have tried every method I know to reference it:
> setting CONFIG "PROJ_LIB" "C:/ms4w/proj/nad/" at the top of my mapfile
> adding the line SetEnv PROJ_LIB "c:/ms4w/proj/nad/" to Apache's
> httpd.conf file
> doing 1 and 2 but omitting the leading "c:"
> Further confirmation that this is the problem is that I tried to set
> the map's projection in MapScript using the line
> mapObj.setProjection("init=epsg:4326");
> and received the PROJ4 error:
> msProcessProjection(): Projection library error. No such file or
> directory
> Any ideas out there?
> Dan Walton
> On Mon, Oct 5, 2009 at 8:49 AM, <jbloc1878 at googlemail.com> wrote:
> Thanks for the response. I am using openlayers and my map does not
> appear unless layer is STATUS DEFAULT.
> I call layer as follows
> layer1 = new OpenLayers.Layer.WMS("OpenLayers WMS",
> "http://localhost/cgi-bin/mapserv.exe?", { layers:
> "testlayer", map: '/ms4w/.../data/tr00.map',
> gutter: 15, minZoomLevel: 1, maxZoomLevel: 10,
> units:'meters' });
> map.addLayer(layer1);
> I only view pink tiles when STATUS ON?
> Thanks
> On 5 Oct 2009, at 14:40, "Fawcett, David"
> <David.Fawcett at state.mn.us> wrote:
>> You don’t. That is how you tell MapServer that you want to view a
>> particular layer that doesn’t have a status of default.
>> In many cases, if you are viewing your map using a client like
>> OpenLayers, the client does this for you.
>> David.
>> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-
>> users-bounces at lists.osgeo.org] On Behalf Of jbloc1878 at googlemail.com
>> Sent: Monday, October 05, 2009 8:31 AM
>> To: mapserver-users at lists.osgeo.org
>> Subject: [mapserver-users] Call layer
>> Hi,
>> If the status of my layer is set to ON how do I call the layer
>> without adding '&layer=[layername]' on the end of the URL?
>> I am viewing the map via localhost/cgi-bin/mapserv.exe?
>> Cheers for any help
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091006/c5a1a481/attachment.html
