[mapserver-users] Problem with configure
Frank Warmerdam
warmerdam at pobox.com
Tue Oct 13 11:35:52 EDT 2009
Alan Hale wrote:
> Hi
> Running on CentOS5 I am getting an error with configure relating to gd.
> Here is the last part of the output:
> libiconv found. Enabling internationalization (-DUSE_ICONV)
> configure: checking for GD 2.0.16 or higher...
> checking for gdFontCacheSetup in -lgd... yes
> configure: error: Could not find gd.h or libgd.a/libgd.so in /usr/lib/.
> Make sure GD 2.0.16 or higher is compiled before calling configure. You
> may also get this error if you didn't specify the appropriate location
> for one of GD's dependencies (freetype, libpng, libjpeg or libiconv).
> And this is my configure line:
> ./configure --with-ogr=/usr/local/bin/gdal-config
> --with-ogr=/usr/local//bin/gdal-config --with-httpd=/usr/sbin/httpd
> --with-wfsclient --with-wmsclient --enable-debug
> --with-curl-config=/usr/local/bin/curl-config --with-proj=/usr/local
> --with-tiff --with-gd=/usr/lib/ --with-jpeg
> --with-freetype=/usr/local/lib/ --with-threads --with-php
> libgd.so is definitely under /usr/lib/ and the script seems to have
> found all the other dependencies listed for GD. Can anyone please advise?
> Many thanks
Alan,
Does gd.h exist in /usr/include or /usr/include/gd*?
If not, you are most likely missing the GD -devel package.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
