[mapserver-users] help in Building mapserver
Smith, Michael ERDC-USACE-NH
michael.smith at usace.army.mil
Tue Oct 13 15:28:06 EDT 2009
The --with-sde-version= \ needs to be there for more recent versions of SDE
(I'm not sure exactly when it changed) as they have stopped including the
version in the library files (eg libsde83.so is used in 8.3 versions, just
libsde.so is used in 9.3).
Mike
On 10/13/09 12:10 PM, "Frank Warmerdam" <warmerdam at pobox.com> wrote:
> Medve Zsolt wrote:
>> Hy!
>> I have a problem to re-build from source code the mapserver because it
>> doesnt work with SDE. (mapserv.com -v gives theres is no SDE input)
>> Can anybody help me? Or do someone know anybody or just a good
>> description about building mapserver? (expecialy SDE)
>> IF you do help me, maybe you can give your MSN or skype arddress in
>> private mail. It is very important to me!
> Zsolt,
> It would have been helpful if you had indicated what steps you have taken
> already to build in SDE support, and of course what platform you are working
> on.
> A recent build against SDE on redhat linux including the following configure
> options and things seem to have worked well:
> --with-sde=/opt/build/arcsde_c_sdk \
> Best regards,
