[mapserver-users] mapserver produces interlaced PNGs even if
I configured the map to output noninterlaced PNGs
Adrian Popa
adrian_gh.popa at romtelecom.ro
Wed Oct 14 09:46:55 EDT 2009
Hmm,
I did that, and kept the same query parameters and I get this error:
msPostMapParseOutputFormatSetup(): General error message. Unable to
select IMAGETYPE `agg'.
So, it seems that imagetype is useful after all.
Guillaume Sueur wrote:
> hi,
> rename your OUTPUTFORMAT to 'PNG' for it to be used when asking for png
> format.
> Guillaume
> Le mercredi 14 octobre 2009 à 16:36 +0300, Adrian Popa a écrit :
>> Hello all,
>> My goal is to setup tilecache (which is proving to be a real pain),
>> and so far I've noticed that even if I configured my map to generate
>> noninterlaced PNGs (instructions here:
>> http://www.mapserver.org/faq.html#why-doesn-t-pil-python-imaging-library-open-my-pngs), it still generates interlaced PNGs.
>> Here is my outputformat (the only one defined) in my map:
>> OUTPUTFORMAT
>> NAME 'AGG'
>> DRIVER AGG/PNG
>> IMAGEMODE RGBA
>> TRANSPARENT ON
>> FORMATOPTION "INTERLACE=OFF"
>> END
>> The parameters that get sent to my mapserver instance are:
>> BBOX
>> 2896046.12635,5831228.011975,2935181.884825,5870363.77045
>> EXCEPTIONS
>> application/vnd.ogc.se_inimage
>> FORMAT
>> png
>> HEIGHT
>> 256
>> LAYERS
>> Judete,RuralSate,Rural,Urban,roads,roads-buc,buildings,GranitaJudete
>> MAP
>> /var/www/html/map/rtc_base.map
>> MAP_IMAGETYPE
>> agg
>> MAXEXTENT
>> left-bottom=(20.26,43.16)
>> right-top=(29.7,48.46)
>> MAXRESOLUTION
>> 156543
>> REQUEST
>> GetMap
>> SERVICE
>> WMS
>> SRS
>> EPSG:900913
>> STYLES
>> TRANSITIONEFFECT
>> resize
>> TRANSPARENT
>> false
>> UNITS
>> m
>> VERSION
>> 1.1.1
>> WIDTH
>> 256
>> I'm not sure if MAP_IMAGETYPE=agg is the one which selects the
>> outputformat or not, but the map seems to be rendered with AGG (I
>> could be wrong, of course).
>> So, what am I missing here? Is there another parameter that should be
>> sent to mapserver to select the outputformat?
>> By the way, the image file generated has these properties: img.png:
>> PNG image, 256 x 256, 8-bit colormap, interlaced
>> Thanks,
>> Adrian
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Adrian Popa
NOC Division
Network Engineer
Divizia Centrul National de Operare Retea
Departament Transport IP & Metro
Compartiment IP Core & Backbone
Phone: +40 21 400 3099
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091014/82e06b39/attachment.html
