[mapserver-users] Making labels appear less often on adjacent
tiles
Adrian Popa
adrian_gh.popa at romtelecom.ro
Thu Oct 15 04:59:20 EDT 2009
Yes, it's clear now. Thanks for the clarification.
Regards,
Adrian
Thomas Bonfort wrote:
> simply put, when using that parameter the label point is chosen using
> geographical coordinates instead of pixel ones, which means that the
> label is anchored to the ground thus making it appear only once even
> if the polygon spans multiple rendered tiles. hope this is
> sufficiently clear ....
> regards,
> thomas
> www.camptocamp.com
> +33 5 16 57 01 02
> On Wed, Oct 14, 2009 at 14:45, Adrian Popa <adrian_gh.popa at romtelecom.ro> wrote:
>> Thank you, Thomas,
>> That worked beautifully. I am curious, though - how does it work? I mean,
>> the requests are independent and as far as I can see there is no "state" on
>> the server telling him some request are part of a larger request. So, how
>> can it know on which tile to show the label and on which tile not to show
>> the label?
>> Thanks
>> yes you can do that, by adding a PROCESSING "LABEL_NO_CLIP=ON" to the
>> layers where you don't want repeated labels.
>> regards,
>> thomas
>> www.camptocamp.com
>> +33 5 16 57 01 02
>> On Wed, Oct 14, 2009 at 13:29, Adrian Popa <adrian_gh.popa at romtelecom.ro>
>> wrote:
>> Hello everyone,
>> I'm sure this subject has been discussed before, but I wasn't able to find
>> relevant information so far, so please point me in the right direction
>> please.
>> I have switched to WMS and I am now getting several tiles from my mapserver
>> for one request (this is desired) (actually there are multiple WMS requests
>> for a specific area). I have no label clipping issues, so that's fine also.
>> The thing is, for example, if I zoom over a town and the town is split
>> between several tiles, I will get a label on each tile for the town name.
>> Previously, when I was requesting a large tile from my mapserver
>> (single-tile), this wouldn't happen.
>> I don't want to set the label to "not be visible" below a certain
>> resolution, because that way I wouldn't get any labels below a point.
>> So, my question is: Is it possible to show the label only once per feature,
>> not once per request? My guess is not (because I wouldn't know how to
>> implement it), but I'm curious if there's a solution...
>> Regards,
>> Adrian
>> --- Adrian Popa
>> NOC Division
>> Network Engineer
>> Divizia Centrul National de Operare Retea
>> Departament Transport IP & Metro
>> Compartiment IP Core & Backbone
>> Phone: +40 21 400 3099
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091015/b6b0e1b8/attachment.html
