[mapserver-users] mapserver+SDE support
Medve Zsolt
medvezs84 at gmail.com
Thu Oct 15 14:53:51 EDT 2009
Hy!
There is a link:
http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL_3.0.html#sde
I do exactly the same steps they mentioned but the SDE support isnt
enabled.
In step 1 i copyed the 2 dll's into the /ms4w/gdalplugins/ from
/ms4w/gdalplugins/ignored/sde-x/
and then in step 2 the commands( ogrinfo and gdal info) should list SDE
support, but they dont. So step 3 is not important until step two work
correctly i think:(
Can someone help me more? Am i do something wrong?
There is a line:
"/Note that you might need to add the ArcGIS location (such as/
/C:/Program Files/ArcGIS/Bin) to your system PATH environment/
/variable. You might need to reboot for changes to take effect."
/I think i made this one too...
Should i have to copy other dll"s in other directories? Or what? PLS help me
Thanks a lot,
Zsolt/
