[mapserver-users] Problem with libjpeg
Andy Colson
andy at squeakycode.net
Mon Oct 19 09:12:24 EDT 2009
Alan Hale wrote:
> Hi
> I had successfully compiled and installed Mapserver recently but when I
> tried to run the Itasca demo I realised I had ommitted to configure with
> gdal. So I untarred fresh source files and ran a new configure, this
> time with gdal, thus:
> ./configure --with-ogr=/usr/local/bin/gdal-config
> --with-gdal=/usr/local/bin/gdal-config --with-httpd=/usr/sbin/httpd
> --with-wfsclient --with-wmsclient --enable-debug
> --with-curl-config=/usr/local/bin/curl-config --with-proj=/usr/local
> --with-tiff --with-gd=/usr/local/ --with-jpeg
> --with-freetype=/usr/local/lib/ --with-threads --with-php=/usr/include/php
> The configure seemed to go OK but after doing make I tried to rum
> mapserv from the command line (./mapserv) and got the error:
> error while loading shared libraries: libjpeg.so.7: cannot open shared
> object file: No such file or directory
> When I check config.log it says "using libjpeg from system libs."
> I then ran config again giving a path to where I know libjpeg.so resides
> I got "Could not find jpeglib.h or libjpeg.a/libjpeg.so/libjpeg.dylib in
> /usr/local/lib/." .... "using libjpeg from system libs."
> Could someone kindly explain what is going on here? Many thanks.
> Alan
First you need to find libjpeg. one way is:
ldconfig -v|grep jpeg
if not there, try a few common places:
ls /usr/lib/libjpeg*
ls /usr/local/lib/libjpeg*
or if you have locate/slocate then try:
slocate libjpeg.so.7
Second, if it seemed to compile ok, then it found the .h files (which are probably in /usr/include or /usr/local/include), but when you run it, its looking for libjpeg.so, and specifically, libjpeg.so.7 which is probably a symlink.
My guess is the lib is in /usr/local/lib, but you dont have that lib in /etc/ld.so.conf.
Probably just need to add that path to the file and then run ldconfig once.
-Andy
