[mapserver-users] Mapserver CGI 5.4 crashed my app (Windows 2003)
Paul james
pauljame at gmail.com
Mon Oct 19 14:40:49 EDT 2009
Testing :
http://localhost/cgi-bin-54/mapserv.exe?map=C:/Mapserver/Mapfile/map.map&mode=map
Using Postgis connection works fine with same setup...
Using that mapfile with MAPSCRIPT/C# works fine as well...
The problem is CGI + MSSQL2008 Plugin
Mapfile:
MAP
EXTENT -79.7892 -34.2426 -24.9958 6.11775
FONTSET "..\Fontes\Fontes.txt"
IMAGECOLOR 230 254 254
IMAGETYPE png
SIZE 400 200
STATUS ON
UNITS dd
NAME "Geral"
OUTPUTFORMAT
NAME "png"
MIMETYPE "image/png"
DRIVER "GD/PNG"
EXTENSION "png"
IMAGEMODE "PC256"
TRANSPARENT TRUE
END
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
WEB
IMAGEPATH 'C:\map\temp'
IMAGEURL '/tmp/'
QUERYFORMAT text/html
LEGENDFORMAT text/html
BROWSEFORMAT text/html
END
LEGEND
STATUS ON
KEYSIZE 18 12
KEYSPACING 10 5
IMAGECOLOR 255 255 255
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
TEMPLATE "..\template.html"
END
QUERYMAP
COLOR 255 0 0
SIZE -1 -1
STATUS ON
STYLE hilite
END
REFERENCE
IMAGE "..\reference.png"
STATUS on
SIZE 221 150
MINBOXSIZE 5
MAXBOXSIZE 150
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
MARKERSIZE 8
END
LAYER
NAME test
GROUP "tests"
TYPE POLYGON
STATUS ON
CONNECTIONTYPE PLUGIN
PLUGIN "msplugin_mssql2008.dll"
CONNECTION "server=x;Integrated Security=false;database=x;uid=x;pwd=x"
DATA "the_geom from viwgeo_paisbrasil USING UNIQUE oid USING SRID=0"
CLASS
COLOR 255 200 255
END
END
END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091019/1d249582/attachment.html
