[mapserver-users] Tiled PNG doesn't work for WCS (and WMS)
Steven M. Ottens
steven.ottens at geodan.nl
Tue Oct 20 06:22:28 EDT 2009
Hi all,
I'm trying to setup a WCS with a series of PNGs with world files.
I've indexed them with gdaltindex.
When I do a WCS getCoverage or a WMS getMap request I get a white
image. However when I configure mapserver to use only one tile as
datasource I get an image (black and white in WCS, color in WMS).
Working singletile datasource WMS: http://bit.ly/smpyA
Working singletile datasource WCS: http://bit.ly/1hXghB
not working tiled datasource WMS: http://bit.ly/2k5J11
I'm running Mapserver 5.0.2 on windows
I've tried to convert the PNGs to geotiff, but that didn't matter.
I've tried using Geoserver and there it does work, so the data
appears to be correct.
Does mapserver support tiled PNGs?
Does it support it for WCS?
Regards,
Steven
The configuration for the two layers::
single tiledatasource:
LAYER
NAME vec200tile
METADATA
"wcs_label" "Swiss Topo Vec200 rendering for Tripod"
### required
"wcs_rangeset_name" "Vector200Range" ###
required to support DescribeCoverage request
"wcs_rangeset_label" "Vec200" ### required to
"wcs_extent" "463179.500000 44100.500000 853179.500000
324100.500000" ### required for tiled datasets [MVEXEL]
"wcs_res" "1 1" ### from gdalinfo, undocumented metadata element
"wcs_size" "10000 10000" ### from gdalinfo, undocumented
metadata element
"wcs_srs" "EPSG:21781 EPSG:3035"
END
EXTENT 463179.500000 44100.500000 853179.500000 324100.500000
TEMPLATE "blank.html"
TYPE RASTER
UNITS METERS
STATUS ON
data "RT_Vec200_1500/1.0/vec200_1500_0_108.png"
PROJECTION
"init=epsg:21781"
END
DUMP TRUE ### required
END
tiled datasource:
LAYER
NAME vec200
METADATA
### required
metadata element
"wcs_srs" "EPSG:27181 EPSG:3035"
END
TYPE RASTER
UNITS METERS
STATUS ON
TILEINDEX RT_Vec200_1500/1.0/sh1.0.shp
TILEITEM "filename"
PROJECTION
"init=epsg:21781"
END
END
Steven M. Ottens -==- http://research.geodan.nl/
