[mapserver-users] Tiled PNG doesn't work for WCS (and WMS)
Frank Warmerdam
warmerdam at pobox.com
Tue Oct 20 11:41:22 EDT 2009
Charlton Galvarino wrote:
> Hi, Frank.
>> I believe much of the performance problem is that some versions of
>> GDALOpen() do a scan of the whole directory as part of the file opening
>> process. In a directory, like Steven's, with 60000 tiles (120000 files!)
>> that becomes a significant performance problem. I have suggested a
>> configuration item that might disable this depending on his version of
>> GDAL.
> That got my attention!
> In one dir say I have 20k .png images. In that same dir I have 400 .shp
> tileindexes which point to them. I.e. each tileindex points to 50 of those
> .png's. Are you saying that when I send a MS viz request based on a
> specific tileindex .shp, I could be scanning the whole dir (depending on my
> version of gdal)?
Charlton,
Yes, for each GDALOpen() request. So for each actual raster file which we
attempt to open.
I would add some other aspects of operating systems may respond poorly to
very large directories so it is a common practice to break down tiling
systems into a heirarchy (like the google tile tree).
I'm not saying your configuration can't be fast, but you are playing with
fire if performance is the goal.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
