[mapserver-users] roadlines issue
Raivo Alla
snaperski at gmail.com
Wed Oct 21 07:30:47 EDT 2009
Hey,
thank You. I was thinking that pre-splitting large datasets would be a
good optimization
step as suggested here: http://mapserver.org/optimization/vector.html
Have to try and compare ;)
Raivo
On Wed, Oct 21, 2009 at 11:45 AM, Pavel Iacovlev
<iacovlev.pavel at gmail.com> wrote:
> First if you have 2 layers for roads like highways.shp and
> secondary.shp (for example) if you make one shape roads.shp file with
> the a field "type" performance will actually improve.
> You can see a great example how to render street data (openstreetmap
> data in this case) here:
> http://trac.osgeo.org/mapserver/wiki/RenderingOsmData
> On Wed, Oct 21, 2009 at 10:16 AM, Raivo Alla <snaperski at gmail.com> wrote:
>> Hello,
>> the problem I have right now with mapserver is how to display roads
>> that must be displayed from different layers in a mapfile,
>> but should have nice joining with each other. Problem is shown here
>> (red arrows):
>> http://picasaweb.google.com/snaperski/Ort#5394941894576868946
>> Desired situation with using multiple mapserver layers is marked with red ring.
>> If I would use just one massive shapefile and take it as a datasource
>> in one layer only (instead using multiple shapefiles/layers
>> drawing highways, streets), then performance will suffer.
>> Is there any solution to this, ie declaring DATA kayword in a CLASS
>> section? :) Or something so simple that I couldnt think of...
>> Humbly yours,
>> Raivo
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> http://iap.md, The future is open
