[mapserver-users] Any ways to increase performance of Mapserver?
Michael Shishcu
micklesh at gmail.com
Wed Oct 21 09:04:44 EDT 2009
Hello, Adrian
add to your apache config the folowing:
ScriptAlias /fcgi-bin/ "path to your mapserver binary file"
<Location "/fcgi-bin">
# The following line activates the fastCGI script to all files in
location
SetHandler fcgid-script
</Location>
regards, michael
2009/10/21 Adrian Popa <adrian_gh.popa at romtelecom.ro>
> Hello again,
> I've compiled mapserver with fast cgi support and I've installed fastcgi on
> my apache. All seems ok, but I'm not sure if mapserver runs as fastcgi! I
> followed the instructions from here:
> http://mapserver.org/optimization/fastcgi.html
> Here's what I've added in the configuration:
> in httpd.conf (Apache2):
> LoadModule fastcgi_module modules/mod_fastcgi.so
> <IfModule mod_fastcgi.c>
> AddHandler fastcgi-script .fcgi
> FastCgiIpcDir /tmp/fastcgi
> FastCgiConfig -initial-env PROJ_LIB=/usr/share/proj -initial-env
> LD_LIBRARY_PATH=/usr/lib:/usr/local/lib:/usr/local/pgsql/lib -appConnTimeout
> 60 -idle-timeout 60 -init-start-delay 1 -minProcesses 2 -maxClassProcesses
> 30 -startDelay 5
> </IfModule>
> When httpd restarts, I get in the logs that fastcgi starts ok:
> [Wed Oct 21 15:43:04 2009] [notice] FastCGI: process manager initialized
> (pid 12570)
> I think I should somehow link mapserv to fastcgi - because I see no obvious
> connection. The script handler is only for .fcgi, but mapserver's
> compilation didn't generate any fcgi files... It seems to me, mapserver
> still runs as a cgi process. If I list the running processes when there are
> no queries to the webserver, there is no mapserv process. When I list the
> processes while doing queries, there are several mapserv processes running.
> Thanks,
> Adrian
> Adrian Popa wrote:
> Thanks,
> I'm compiling mapserver with fast-cgi support and see how that works out.
> Any idea if there is a difference in terms of speed if I make normal CGI
> queries vs WMS queries?
> Regards,
> Adrian
> Pavel Iacovlev wrote:
> Fast-cgi is one process that manages all your connections (acts more
> like apache module) cgi creates a new process for every connection so
> fast-cgi is faster and consumes less resources.
> The best performance you should get with tilecache serving TMS(If it's
> supported by your client, openlayers supports it), images are request
> directly so there is almost no overhead
> On Wed, Oct 21, 2009 at 10:42 AM, Adrian Popa<adrian_gh.popa at romtelecom.ro> <adrian_gh.popa at romtelecom.ro> wrote:
> Hello, sorry for this noobie question, but I have been running mapserver as
> a cgi process and sometimes I need to make lots of calls to it to get the
> data I want. I have used TileCache to get the layers I need and which don't
> change over time and it speeds things up considerably.
> I was wondering - is it possible (and is it more efficient?) to run
> mapserver as fast-cgi? Would it increase speed? The mapserver in the cgi-bin
> directory is already a binary file - so I'm not sure if fast-cgi would do
> any good.
> Also, would I have any extra speed benefits if I make WMS queries instead of
> regular cgi queries?
> Thank you,
> Adrian
> mapserver-users mailing listmapserver-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091021/e1a0dcc0/attachment.html
