[mapserver-users] long expression statement doesn't work anymore
Steve Lime
Steve.Lime at dnr.state.mn.us
Wed Oct 21 11:20:09 EDT 2009
Any chance you could create a simple test case showing the problem? The fact it shows some
features is puzzling. If it was just a matter of the expression getting truncated then you should
see an expression parse error.
Steve
>>> Rafael Szajbel <szajbel at widemann.de> 10/21/2009 6:58 AM >>>
Hello,
in an older MapServer version (4.10.0) it is possible to use a very long Expression or Filter statement.
Like this one with over 1000 comma separated values:
EXPRESSION ('[NR]' IN 'ID1,ID2,.................,ID1100')
This works fine:
With newer MapServer versions (whether cgi (expression in mapfile) or phpmapscript (expression set with setExpression)) like 5.2.1 or 5.6.0 beta3 only o small part of the polygons appears:
So is there a limit on expression statement since version 5?
There are no errors in the log-file with debug set to 5.
This is my layer definition:
LAYER
DATA "shapes/fs.shp"
NAME "FS"
STATUS ON
TYPE POLYGON
CLASS
NAME "FS"
EXPRESSION ('[NR]' IN 'ID1,ID2,.............................,ID1100') # <-- of course without the points ;)
STYLE
COLOR 255 255 200
OUTLINECOLOR 0 0 0
END
END
END
Thanks for any hint.
Rafael
PS: It is not possible to classify on attributes.
