[mapserver-users] Mapserver CGI 5.4 crashed my app (Windows 2003)
Paul james
pauljame at gmail.com
Thu Oct 22 10:29:29 EDT 2009
Hi Tamas!
Thanks...
Yes, thats working on Windows 2003/XP...
The problem is happening only on Windows 7 (IIS 7.5) now...
HTTP Error 502.2 - Bad Gateway
Do you have any idea what is that? Its work fine with postgis...
Paul
On Wed, Oct 21, 2009 at 5:00 PM, Tamas Szekeres <szekerest at gmail.com> wrote:
> Paul,
> I've set up your data but it works for me:
> http://vbkto.dyndns.org/cgi-bin/mapserv.exe?mode=map&map=mssql2008.map
> tried with the following binaries:
> http://vbkto.dyndns.org/sdk/release-1500-gdal-1-6-mapserver-5-4.zip
> http://vbkto.dyndns.org/sdk/release-1500-gdal-mapserver.zip
> My mapfile:
> MAP
> NAME "SQL2008"
> STATUS ON
> SIZE 500 500
> IMAGETYPE PNG
> IMAGECOLOR 254 254 254
> EXTENT -79.7892 -44.2426 -24.9958 -9.11775
> LAYER
> NAME "tblGeo_AmericaSul"
> TYPE POLYGON
> CONNECTIONTYPE PLUGIN
> PLUGIN "msplugin_mssql2008.dll"
> CONNECTION
> "server=.\MSSQLSERVER2008;database=Maps;Integrated Security=true"
> DATA "the_geom from tblGeo_AmericaSul USING UNIQUE
> CodigoAmericaSul USING SRID=0"
> STATUS DEFAULT
> CLASS
> STYLE
> COLOR 255 0 0
> END
> END
> END
> END
> Best regards,
> Tamas
> 2009/10/21 Paul james <pauljame at gmail.com>
> Tamas, the actual error generated is:
>> The specified CGI application misbehaved by not returning a complete set
>> of HTTP headers. The headers it did return are "".
>> Using Windos 7 (IIS 7)
>> Testing on Windows 2003, I got just a Blank image (no error message)...
>> You can use the same mssql2008 data I sended you last time...
>> Paul
>> On Tue, Oct 20, 2009 at 4:56 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>>> Paul,
>>> I couldn't reproduce your problem by using my data and the recent mapserv
>>> version.
>>> http://vbkto.dyndns.org/cgi-bin/mapserv.exe?mode=map&map=sql2008.map
>>> Could you provide your data for testing?
>>> Best regards,
>>> Tamas
>>> 2009/10/20 Paul james <pauljame at gmail.com>
>>> Hello Tamas
>>>> Did you test that?
>>>> Paul
>>>> On Mon, Oct 19, 2009 at 3:40 PM, Paul james <pauljame at gmail.com>wrote:
>>>>> Testing :
>>>>> http://localhost/cgi-bin-54/mapserv.exe?map=C:/Mapserver/Mapfile/map.map&mode=map
>>>>> Using Postgis connection works fine with same setup...
>>>>> Using that mapfile with MAPSCRIPT/C# works fine as well...
>>>>> The problem is CGI + MSSQL2008 Plugin
>>>>> Mapfile:
>>>>> MAP
>>>>> EXTENT -79.7892 -34.2426 -24.9958 6.11775
>>>>> FONTSET "..\Fontes\Fontes.txt"
>>>>> IMAGECOLOR 230 254 254
>>>>> IMAGETYPE png
>>>>> SIZE 400 200
>>>>> STATUS ON
>>>>> UNITS dd
>>>>> NAME "Geral"
>>>>> OUTPUTFORMAT
>>>>> NAME "png"
>>>>> MIMETYPE "image/png"
>>>>> DRIVER "GD/PNG"
>>>>> EXTENSION "png"
>>>>> IMAGEMODE "PC256"
>>>>> TRANSPARENT TRUE
>>>>> END
>>>>> PROJECTION
>>>>> 'proj=longlat'
>>>>> 'ellps=WGS84'
>>>>> 'datum=WGS84'
>>>>> 'no_defs'
>>>>> END
>>>>> WEB
>>>>> IMAGEPATH 'C:\map\temp'
>>>>> IMAGEURL '/tmp/'
>>>>> QUERYFORMAT text/html
>>>>> LEGENDFORMAT text/html
>>>>> BROWSEFORMAT text/html
>>>>> END
>>>>> LEGEND
>>>>> STATUS ON
>>>>> KEYSIZE 18 12
>>>>> KEYSPACING 10 5
>>>>> IMAGECOLOR 255 255 255
>>>>> LABEL
>>>>> TYPE BITMAP
>>>>> SIZE MEDIUM
>>>>> COLOR 0 0 89
>>>>> END
>>>>> TEMPLATE "..\template.html"
>>>>> END
>>>>> QUERYMAP
>>>>> COLOR 255 0 0
>>>>> SIZE -1 -1
>>>>> STATUS ON
>>>>> STYLE hilite
>>>>> END
>>>>> REFERENCE
>>>>> IMAGE "..\reference.png"
>>>>> STATUS on
>>>>> SIZE 221 150
>>>>> MINBOXSIZE 5
>>>>> MAXBOXSIZE 150
>>>>> COLOR -1 -1 -1
>>>>> OUTLINECOLOR 255 0 0
>>>>> MARKERSIZE 8
>>>>> END
>>>>> LAYER
>>>>> NAME test
>>>>> GROUP "tests"
>>>>> TYPE POLYGON
>>>>> STATUS ON
>>>>> CONNECTION "server=x;Integrated
>>>>> Security=false;database=x;uid=x;pwd=x"
>>>>> DATA "the_geom from viwgeo_paisbrasil USING UNIQUE oid USING SRID=0"
>>>>> CLASS
>>>>> COLOR 255 200 255
>>>>> END
>>>>> END
>>>>> END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091022/c28040f3/attachment.html
