[mapserver-users] Mapserver CGI 5.4 crashed my app (Windows 2003)
Paul james
pauljame at gmail.com
Thu Oct 22 12:30:23 EDT 2009
I got it work...
It was a IIS 7.5 Mapping problem...
My bad...
Sorry
Paul
On Thu, Oct 22, 2009 at 12:03 PM, Milo van der Linden <mlinden at zeelandnet.nl
> wrote:
> I had my IIS crash so severe after a windows update once that it forced
> me to switch to ms4w...
> Mostly, it has to do with rights/authentication. Are you sure your IIS
> user is allowed to connect to your database?
> Daniel Walton schreef:
> > Paul,
> > I got various errors with MapServer running in IIS 7.5 until I
> > installed the latest build of PHP. Don't know if you've done that
> > already, but I thought I would mention it.
> > Regards,
> > Dan Walton
> > gisfiretools.com <http://gisfiretools.com>
> > On Thu, Oct 22, 2009 at 9:29 AM, Paul james <pauljame at gmail.com
> > <mailto:pauljame at gmail.com>> wrote:
> > Hi Tamas!
> > Thanks...
> > Yes, thats working on Windows 2003/XP...
> > The problem is happening only on Windows 7 (IIS 7.5) now...
> > HTTP Error 502.2 - Bad Gateway
> > Do you have any idea what is that? Its work fine with postgis...
> > Paul
> > On Wed, Oct 21, 2009 at 5:00 PM, Tamas Szekeres
> > <szekerest at gmail.com <mailto:szekerest at gmail.com>> wrote:
> > Paul,
> > I've set up your data but it works for me:
> http://vbkto.dyndns.org/cgi-bin/mapserv.exe?mode=map&map=mssql2008.map
> http://vbkto.dyndns.org/cgi-bin/mapserv.exe?mode=map&map=mssql2008.map>
> > tried with the following binaries:
> http://vbkto.dyndns.org/sdk/release-1500-gdal-1-6-mapserver-5-4.zip
> > http://vbkto.dyndns.org/sdk/release-1500-gdal-mapserver.zip
> > My mapfile:
> > MAP
> > NAME "SQL2008"
> > STATUS ON
> > SIZE 500 500
> > IMAGETYPE PNG
> > IMAGECOLOR 254 254 254
> > EXTENT -79.7892 -44.2426 -24.9958 -9.11775
> > LAYER
> > NAME "tblGeo_AmericaSul"
> > TYPE POLYGON
> > CONNECTIONTYPE PLUGIN
> > PLUGIN "msplugin_mssql2008.dll"
> > CONNECTION
> > "server=.\MSSQLSERVER2008;database=Maps;Integrated Security=true"
> > DATA "the_geom from tblGeo_AmericaSul USING
> > UNIQUE CodigoAmericaSul USING SRID=0"
> > STATUS DEFAULT
> > CLASS
> > STYLE
> > COLOR 255 0 0
> > END
> > END
> > END
> > END
> > Best regards,
> > Tamas
> > 2009/10/21 Paul james <pauljame at gmail.com
> > Tamas, the actual error generated is:
> > The specified CGI application misbehaved by not returning
> > a complete set of HTTP headers. The headers it did return
> > are "".
> > Using Windos 7 (IIS 7)
> > Testing on Windows 2003, I got just a Blank image (no
> > error message)...
> > You can use the same mssql2008 data I sended you last time...
> > Paul
> > On Tue, Oct 20, 2009 at 4:56 PM, Tamas Szekeres
> > Paul,
> > I couldn't reproduce your problem by using my data and
> > the recent mapserv version.
> http://vbkto.dyndns.org/cgi-bin/mapserv.exe?mode=map&map=sql2008.map
> http://vbkto.dyndns.org/cgi-bin/mapserv.exe?mode=map&map=sql2008.map>
> > Could you provide your data for testing?
> > Best regards,
> > Tamas
> > 2009/10/20 Paul james <pauljame at gmail.com
> > Hello Tamas
> > Did you test that?
> > Paul
> > On Mon, Oct 19, 2009 at 3:40 PM, Paul james
> > <pauljame at gmail.com <mailto:pauljame at gmail.com>>
> > wrote:
> > Testing :
> http://localhost/cgi-bin-54/mapserv.exe?map=C:/Mapserver/Mapfile/map.map&mode=map
> > Using Postgis connection works fine with same
> > setup...
> > Using that mapfile with MAPSCRIPT/C# works
> > fine as well...
> > The problem is CGI + MSSQL2008 Plugin
> > Mapfile:
> > MAP
> > EXTENT -79.7892 -34.2426 -24.9958 6.11775
> > FONTSET "..\Fontes\Fontes.txt"
> > IMAGECOLOR 230 254 254
> > IMAGETYPE png
> > SIZE 400 200
> > STATUS ON
> > UNITS dd
> > NAME "Geral"
> > OUTPUTFORMAT
> > NAME "png"
> > MIMETYPE "image/png"
> > DRIVER "GD/PNG"
> > EXTENSION "png"
> > IMAGEMODE "PC256"
> > TRANSPARENT TRUE
> > END
> > PROJECTION
> > 'proj=longlat'
> > 'ellps=WGS84'
> > 'datum=WGS84'
> > 'no_defs'
> > END
> > WEB
> > IMAGEPATH 'C:\map\temp'
> > IMAGEURL '/tmp/'
> > QUERYFORMAT text/html
> > LEGENDFORMAT text/html
> > BROWSEFORMAT text/html
> > END
> > LEGEND
> > STATUS ON
> > KEYSIZE 18 12
> > KEYSPACING 10 5
> > IMAGECOLOR 255 255 255
> > LABEL
> > TYPE BITMAP
> > SIZE MEDIUM
> > COLOR 0 0 89
> > END
> > TEMPLATE "..\template.html"
> > END
> > QUERYMAP
> > COLOR 255 0 0
> > SIZE -1 -1
> > STATUS ON
> > STYLE hilite
> > END
> > REFERENCE
> > IMAGE "..\reference.png"
> > STATUS on
> > SIZE 221 150
> > MINBOXSIZE 5
> > MAXBOXSIZE 150
> > COLOR -1 -1 -1
> > OUTLINECOLOR 255 0 0
> > MARKERSIZE 8
> > END
> > LAYER
> > NAME test
> > GROUP "tests"
> > TYPE POLYGON
> > STATUS ON
> > CONNECTION "server=x;Integrated
> > Security=false;database=x;uid=x;pwd=x"
> > DATA "the_geom from viwgeo_paisbrasil USING
> > UNIQUE oid USING SRID=0"
> > CLASS
> > COLOR 255 200 255
> > END
> > END
> > END
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > <mailto:mapserver-users at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091022/33f5f72a/attachment-0001.html
