[mapserver-users] templates, queries & the web object
Ted Spradley
tspradley at snoogems.com
Thu Oct 22 16:19:43 EDT 2009
Hi all,
The Mapserver Test Suite /featurenquery directory test.map includes
WEB
IMAGEPATH "set in config.js"
IMAGEURL "set in config.js"
TEMPLATE test.html
MAXSCALE 8000000
MINSCALE 100000
HEADER top.html # only used in conjunction with queries...
FOOTER bottom.html
END
# Then three default query layers like the following
LAYER
NAME usgs250kq
DATA usgs250k
STATUS DEFAULT
TYPE QUERY
HEADER "250k_top.html"
FOOTER quad_bottom.html
CLASS
TEMPLATE quad.html
END
END
LAYER
NAME counties
DATA county
STATUS DEFAULT
TYPE POLYGON
TOLERANCE 10
HEADER "counties_header.html"
FOOTER "counties_footer.html"
CLASS
TEMPLATE "counties.html"
NAME "Minnesota Counties"
COLOR 212 212 212
OUTLINECOLOR 0 0 0
END
END
Does the inclusion of HEADER & FOOTER directives in the WEB object mean that
MapServer will begin
and end the query response with these files? Then in between the WEB
HEADER/FOOTER look for any other layers to be queried and use their
HEADER/TEMPLATE/FOOTER combinations?
Thank you,
Ted S.
View this message in context: http://n2.nabble.com/templates-queries-the-web-object-tp3874780p3874780.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
