[mapserver-users] AGG Rendering problem
Tony Baylis
tony.baylis at resexmap.com.au
Mon Oct 26 09:15:13 EDT 2009
Hi all,
This is my first post in a long time so be gentle...My problem is I have
finally updated an old server to use MapServer 5.4.2 and want to use AGG
rendering I have done this without a problem on another server earlier
in the year but for some reason whenever I add the 'OUTPUTFORMAT'
section and remove 'IMAGETYPE' I get a Connection Lost type error from
the browser. Replace 'IMAGETYPE' and the connection is restored but the
map is definitely not anti-aliased.
Below is the relevant section from my mapfile and below that the output
from a ./mapserv -v. Both outputs match the server that works.
#IMAGETYPE JPEG
OUTPUTFORMAT
NAME "AGG_JPEG"
DRIVER "AGG/JPEG"
IMAGEMODE RGB
END
./mapserv -vMapServer version 5.4.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_CLIENT SUPPORTS=FASTCGI SUPPORTS=GEOS INPUT=TIFF
INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Here's hoping you can help.
Tony
Tony Baylis
Spatial Information Specialist
Resource and Exploration Mapping
Suite 8, 290 Boundary St
Spring Hill QLD 4000
Ph 3832 1600
Fax 3832 1603
Mob 0419 759 131
Email tony.baylis at resexmap.com.au
www resexmap.com.au
