[mapserver-users] FW: Character symbology to follow line direction
Bob Basques
bob.b at gritechnologies.com
Tue Oct 27 19:36:13 EDT 2009
You can do this within a LABEL block, see here for more info:
http://mapserver.org/mapfile/label.html?highlight=follow%20auto
HINT: use "ANGLE auto" or "ANGLE follow"
bobb
Todd Harris wrote:
> Hello list,
> A little problem, I hope someone can help.
> Using Mapserver 5.2 - I am attempting to use a character symbol: "|"
> as a STYLE for the outline of a polygon class. However, I cannot get
> the symbol to remain perpendicular to the polygon boundaries ie: the
> symbol is always vertical. Can this be done or should I be using a
> vector or point symbol somehow?
> /Symbol file:/
> SYMBOL
> NAME "rawmat"
> TYPE truetype
> FONT arial
> CHARACTER "|"
> GAP 20 # distance between symbols
> END
> /Mapfile/
> CLASS
> NAME 'Extraction Areas'
> STYLE
> OUTLINECOLOR 0 0 0
> WIDTH 1
> ANTIALIAS TRUE
> END #STYLE
> STYLE
> SYMBOL 'rawmat'
> OUTLINECOLOR 0 0 0
> SIZE 5
> ANTIALIAS TRUE
> END #STYLE
> END #CLASS
> Regards
> Todd
> This e-mail and any files transmitted with it are intended only for
> the use of the addressee(s). It may contain information that is
> confidential and privileged, in which case neither is intended to be
> waived or lost by mistaken delivery to you. If you are not an intended
> recipient, any use, interference with, disclosure, distribution or
> copying of this material is unauthorised and prohibited. If you
> receive this e-mail in error, please notify the sender by return
> e-mail and delete the message and any attachments from your system.
> Unless specifically indicated, this e-mail does not constitute formal
> advice or commitment by the sender or the Western Australian Land
> Information Authority (Landgate). Information in this message not
> relating to the official business of Landgate shall be understood as
> neither given nor endorsed by it. It is your responsibility to check
> any attachments for viruses and defects before opening or sending them
> on. Landgate's liability is limited to re-supplying affected attachments.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091027/90681f5a/attachment-0001.html
