[mapserver-users] FW: Character symbology to follow line direction
Todd Harris
Todd.Harris at landgate.wa.gov.au
Tue Oct 27 22:55:18 EDT 2009
Ah...that's it, thanks Steve!!
Todd
-----Original Message-----
From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
Sent: Wednesday, 28 October 2009 11:41 AM
To: Todd Harris
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] FW: Character symbology to follow line
direction
Todd,
You have to set the gap to a negative number to keep the symbol
perpendicular to the edge.
GAP -20
-Steve W
Todd Harris wrote:
> Hello list,
> A little problem, I hope someone can help.
> Using Mapserver 5.2 - I am attempting to use a character symbol: "|"
as
> a STYLE for the outline of a polygon class. However, I cannot get the
> symbol to remain perpendicular to the polygon boundaries ie: the
symbol
> is always vertical. Can this be done or should I be using a vector or
> point symbol somehow?
> / Symbol file: /
> SYMBOL
> NAME "rawmat"
> TYPE truetype
> FONT arial
> CHARACTER "|"
> GAP 20 # distance between symbols
> END
> / Mapfile /
> CLASS
> NAME 'Extraction Areas'
> STYLE
> OUTLINECOLOR 0 0 0
> WIDTH 1
> ANTIALIAS TRUE
> END #STYLE
> STYLE
> SYMBOL 'rawmat'
> OUTLINECOLOR 0 0 0
> SIZE 5
> ANTIALIAS TRUE
> END #STYLE
> END #CLASS
> Regards
> Todd
This e-mail and any files transmitted with it are intended only for the use of the addressee(s). It may contain information that is confidential and privileged, in which case neither is intended to be waived or lost by mistaken delivery to you. If you are not an intended recipient, any use, interference with, disclosure, distribution or copying of this material is unauthorised and prohibited. If you receive this e-mail in error, please notify the sender by return e-mail and delete the message and any attachments from your system. Unless specifically indicated, this e-mail does not constitute formal advice or commitment by the sender or the Western Australian Land Information Authority (Landgate). Information in this message not relating to the official business of Landgate shall be understood as neither given nor endorsed by it. It is your responsibility to check any attachments for viruses and defects before opening or sending them on. Landgate’s liability is limited to re-supplying affected attachments.
