[mapserver-users] Use of palette file: Problems with changing
colors when tiling
Thomas Bonfort
thomas.bonfort at camptocamp.com
Wed Oct 28 14:34:11 EDT 2009
is the blue of your lake inside your palette.txt ?
if so, you shouldn't be getting those discrepancies.
regards,
thomas
www.camptocamp.com
+33 5 16 57 01 02
On Wed, Oct 28, 2009 at 11:25, Espen Isaksen <espen.isaksen at gmail.com> wrote:
> Hi!
> We are testing out using a palette file in our outputformat to
> decrease file size in the png output. Most of the time this works
> great, but some times when we are tiling the data we get some errors.
> The color seem to shift to a similar color from one tile to another.
> We have added the colors we use in the map file in the palette.txt
> file. The documentation says it needs 256 colors in the map file, but
> we do not use that many colors right now. (we tried adding the same
> color more than one time, but that created other problems....)
> I have attached a png file showing the problem across a lake. The
> color on the right side is the correct color and the color we have
> added to the palette file. The color on the left side of the lake is
> not something we have set.
> I have also added the palette.txt file and the outputformat we use is this:
> OUTPUTFORMAT
> NAME "png"
> DRIVER "AGG/PNG"
> MIMETYPE "image/png"
> IMAGEMODE "rgb"
> EXTENSION "png"
> FORMATOPTION "PALETTE_FORCE=TRUE"
> FORMATOPTION "PALETTE=/data/maps/palette.txt"
> END
> Does anybody know why this happens in Mapserver and how to fix it?
> Espen
> mapserver-users at lists.osgeo.org
