[mapserver-users] OSM data rendering using Mapserver
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Thu Oct 29 08:30:46 EDT 2009
Hi
Ali_ wrote:
> 2) The osm_line and osm_road table have not been assigned the
> primary key while conversion using osm2pgsql and where we
> query in the map file we use USING UNIQUE osm_id which may be
> incompatible and may be make is unable to give the result.
At least the osm2pgsql version I am using is creating dublicate osm_ids
on these layers because relations which are converted to lines are
getting the osm_id of a relation and there can also be same osm_id used
by an OSM line feature. Mapfile works still even it if USING UNIQUE
refers to a non unique field.
-Jukka Rahkonen-
