[mapserver-users] Re: annotations in mapserver 5.4
Raivo Alla snaperski at gmail.com
Tue Sep 1 01:42:40 EDT 2009
Thanks!
You're right, I shortened the layer definition here confusingly, whole
layer definition was like that:
LAYER
		NAME alevikAnno_1
		GROUP HYBRID
		METADATA
			"wms_title" "alevikAnno"
			"wms_srs" "EPSG:3301"
			"wms_extent" "355000 6360000 754000 6660000"
		END
		STATUS default
		TYPE annotation
		DATA "kohanimed/alevikud_1"
		#sama andmestik, mis newages.
		#Uuendamine vastavalt vajadusele.
		#OPACITY 100
		LABELITEM "TEXTSTRING"
		CLASS
		MAXSCALE 1333333 #1000000
		MINSCALE 400000 #300000
		  STYLE
		   SYMBOL "punsoon3"
		   SIZE 15
		  END
			LABEL
				TYPE truetype
				ANTIALIAS true
				FONT "arial"
				COLOR 255 255 255
				SIZE 9
				priority 6
				encoding utf-8
				force false
				ANGLE auto
				OUTLINECOLOR 25 25 25
				POSITION cr
				BUFFER 1
			END
		END
		CLASS
		MAXSCALE 400000 #300000
		MINSCALE 200000 #150000
		  STYLE
		   SYMBOL "punsoon4"
		   SIZE 15
		  END
			LABEL
				TYPE truetype
				ANTIALIAS true
				FONT "arialb"
				COLOR 255 255 255
				SIZE 9
				force false
				ANGLE auto
				priority 6
				POSITION cr
				BUFFER 1
			END
		END
		CLASS
		MAXSCALE 200000 #150000
		MINSCALE 66666 #50000
			LABEL
				TYPE truetype
				ANTIALIAS true
				FONT "arialb"
				COLOR 255 255 255
				SIZE 10
				#force true
				priority 8
				ANGLE auto
				POSITION cc
				BUFFER 3
			END
		END
		CLASS
		MAXSCALE 66666 #50000
		MINSCALE 20000 #15000
			LABEL
				TYPE truetype
				ANTIALIAS true
				FONT "arialb"
				COLOR 255 255 255
				SIZE 11
				#force true
				priority 8
				ANGLE auto
				POSITION cc
				BUFFER 3
			END
		END
		CLASS
		MAXSCALE 20000 #15000
			LABEL
				TYPE truetype
				ANTIALIAS true
				FONT "arialb"
				COLOR 255 255 255
				SIZE 12
				#force true
				priority 8
				ANGLE auto
				POSITION cc
				BUFFER 3
			END
		END
       END
But problem still remains, even if I changed layer definition to
one-class only and with the scales defined in LAYER, not CLASS
section.
Raivo
On Mon, Aug 31, 2009 at 9:16 PM, Steve Lime<Steve.Lime at dnr.state.mn.us> wrote:
> If you get rid of the class min/max scales do the problems go away? What if you put those constraints
> at the layer level (with only one class that should work). Also, the layer defn is confusing since it doesn't
> hint at a marker yet the images missing labels definitely do have a marker accompanying the text.
> Steve
>>>> On 8/31/2009 at 5:23 AM, in message
> <49dc012b0908310323j7868aed2gea5cf8528a23e0f at mail.gmail.com>, Raivo Alla
> <snaperski at gmail.com> wrote:
>> This is a bit old problem (still got that bug), but I found that I
>> typed the second link not right, the right link to
>> the problematic output is that:
>> http://picasaweb.google.com/snaperski/Ort#5365984697960162578
>> I assume this is some 5.4 version bug?
>> Sincerely,
>> Raivo
>> On Tue, Aug 4, 2009 at 9:12 AM, Raivo Alla<snaperski at gmail.com> wrote:
>>> Hey,
>>> I got some weird behavior while trying to display labels with mapserver 5.4.
>>> With mapserver 5.0.3 these labels show up nicely:
>>> http://picasaweb.google.com/snaperski/Ort#5365984694609689634
>>> But with mapserver 5.4, these layers are shown at scale about
>>> 350000-200000, but they will disappear at higher scales, so nothing
>>> can be seen:
>>> This could'nt be collision conflict either as they have enough space to fit
>> in.
>>> Is something changed in the way mapserver treats annotations elements?
>>> Data source is a polygon shapefile: I hope that (polygon type) is not
>>> the problem?
>>> The layer itself in the mapfile:
>>>        LAYER
>>>                NAME alevikAnno_1
>>>                GROUP HYBRID
>>>                METADATA
>>>                END
>>>                STATUS default
>>>                TYPE annotation
>>>                CLASS
>>>                MAXSCALE 1333333
>>>                MINSCALE 200000
>>>                        LABEL
>>>                                TYPE truetype
>>>                                ANTIALIAS true
>>>                                FONT "arial"
>>>                                COLOR 255 255 255
>>>                                SIZE 9
>>>                                priority 6
>>>                                force false
>>>                                ANGLE auto
>>>                                POSITION cr
>>>                                BUFFER 1
>>>                        END
>>>                END
>>>        END
>>> Raivo Alla
>>> Estonian Land Board
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
