[mapserver-users] CGI Controls - queryfile and
pattern validationproblem
Olivier Bedel
o.bedel at alkante.com
Tue Sep 1 04:25:04 EDT 2009
It works !
Thanks a lot.
Olivier
Steve Lime wrote:
> Query files *must* have the extension .qy. There is no workaround other than to rename
> the file.
> Steve
>>>> On 8/27/2009 at 5:46 AM, in message <4A9663F7.2070807 at alkante.com>, Olivier
> Bedel <o.bedel at alkante.com> wrote:
>> Hello list,
>> I am trying to call mapserv in CGI using NQUERYMAP mode. I would like to use
>> the queryfile parameter but I have difficulties setting the validation
>> pattern on it. My URL call looks like this :
>> http://localhost/cgi-bin/mapserv?
>> map=test_postgis.map&
>> LAYERS=layer86&
>> map_imagetype=png&
>> map_transparent=TRUE&
>> map_resolution=96&
>> mapext=603029.1235762136+1779885.0319475005+1031002.8072237864+1903874.97316
>> 24997&
>> imgext=603029.1235762136+1779885.0319475005+1031002.8072237864+1903874.97316
>> 24997&
>> map_size=2464+714&
>> imgx=1232&imgy=357&
>> imgxy=2464+714&
>> mode=nquerymap&
>> queryfile=myquery.msv
>> And mapserv always complains with the following error :
>> msEvalRegex(): Regular expression error. String (myquery.msv) failed
>> expression test.
>> I've tried setting validation patterns in the MAP/WEB/METADATA section of
>> the mapfile :
>> "TEMPLATEPATTERN" ".*"
>> "qstring_validation_pattern" ".*"
>> "queryfile_validation_pattern" ".*"
>> But none of these patterns resolve the problem...
>> Can anyone tell me if CGI queryfile parameter is still supported or if i do
>> something wrong with my patterns ?
>> I am using mapserver 5.4.1
>> Best regards,
>> Olivier.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Olivier BEDEL
ALKANTE SAS
Ingénieur R&D SIG
1, rue du Chêne Morand
35 510 Cesson-Sévigné
Bur: + 33 (0) 2 99 22 25 70
fax : + 33 (0) 2 99 32 12 76
