[mapserver-users] OGR shapefile w/MySQL Join
Greg Luker
gluker at scu.edu.au
Thu Sep 3 02:15:09 EDT 2009
Hi mapservers,
At 12:47 AM 3/09/2009, Steve Lime wrote:
>Hi all: Anyone have a sample configuration for creating an OGR layer
>joined to a MySQL table? The
>MySQL table has no spatial component. I believe it's possible but
>haven't stumbled upon a concrete
>example showing how. Figured better just to ask... Thanks.
I'd be really interested to see how you get this to work, Steve. I
cannot get the JOIN command to work, even on a simple csv file.
Here's what I have tried:
LAYER
NAME "squares"
TYPE POLYGON
STATUS ON
DATA "squares"
CLASS
END
TOLERANCE 20
TEMPLATE "testm_template.html"
HEADER "testm_header.html"
FOOTER "testm_footer.html"
JOIN
NAME "jointest"
TABLE "testm.csv"
FROM "IDENT"
TO "id"
END
END #of layer
testm.csv is in the same directory as the mapfile. The shapefile
(squares) shows up fine, but querying it gives this message:
Status: 302 Found Uri: http://.../errors/errors.html Location:
http://.../errors/errors.html Content-type: text/html
and this debug message:
[Thu Sep 3 15:37:43 2009].493754 msDBFJoinConnect(): Unable to
access file. (testm.csv)
Commenting out the JOIN lines gives correct expected results, so I
assume everything else is in the right place (including template
files). I've tried a few variations of "testm.csv" - like
"'testm.csv'" and "/full/pathname/to/testm.csv" but still no luck. I
tried JOINing a shape to an OGR MySQL table, but that didn't work,
which is why I dropped back to testing with a simple csv JOIN.
Any ideas?
Thanks,
Greg.
Greg Luker
GIS Lab Manager, Southern Cross University
Lismore, AUSTRALIA.
phone 61 2 66203026
