[mapserver-users] turning on layers at a particular zoom level
Bill Thoen
bthoen at gisnet.com
Wed Sep 9 09:53:35 EDT 2009
sunny74 wrote:
> I am now loading the layers in groups instead of individually.
> First I am loading the base layer followed by 4 groups of layers, first
> group contains 2 while others contain 3 each.
> But the problem now is that at PageLoad for the first time the layers of
> group1 are not visible because it is getting overlapped by the other layers.
> The other layers are also not visible bec' they are mandated to be visible
> at higher zoomin levels because of max/min scaledom.
> Now if I load the group1 layers last then not only is it visible at initial
> zoom level but also at higher zoom levels bec' in that case it is
> overlapping the other layers mandated to be visible at that level.
> So how to tackle the problem.
Tricky, isn't it?
Sometimes it helps to use different mapfiles for different zoom levels.
There is a way to automatically switch to a different mapfile when the
current one goes beyond its maximum or minimum scale, but I don't
remember how to do that just now. Hmm.... and I can't find it in the
docs either. Probably because I forget what it's called. It was useful
for even doing projection changes as the map became more local. I
believe it's one of the MAX/MIN commands.
I also found that some effects that I wanted couldn't be done exactly
the way I wanted, but there was always a way to reorganize and set
things up to get what I needed.
