[mapserver-users] MINSCALEDENOM did not work?
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Mon Sep 14 02:18:20 EDT 2009
Minscaledenom does work for me as supposed. If I set it to value 1:10000 I can see the layer in scale 1:11000 because scale demoninator is bigger than my limit. In scale 1:9000 it does not show. But I see that you have understood correctly that because map scale is a division, big number under the line means small scale.
MINSCALEDENOM is used just as you have done, by adding a line into LAYER definitions. I have no idea why it would not work.
-Jukka Rahkonen-
Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Mr. Bic Phuong
Lähetetty: 13. syyskuuta 2009 21:45
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] MINSCALEDENOM did not work?
DDear everyone,
Do you know how to make MINSCALEDENOM work?
In ArcMap, I set minimum scale of layer to 1:10,000 then:
- when I zoom to larger scale (for example: 1:9000, 1:8000 ...), the layer is still displayed
- when I zoom to smaller scale (for example: 1:11000, 1:12000 ...), the layer is not displayed
In the map file of mapserver, I set "MINSCALEDENOM 10000" but the layer is display on every scale. I think MINSCALEDENOM did not work.
I do not know how to make MINSCALEDENOM work. I hope you are please to help me.
Thanks for your attention
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090914/160579bc/attachment.html
