[mapserver-users] WMS Client Error Handling
Chris Hodgson
chodgson at refractions.net
Wed Sep 16 15:58:30 EDT 2009
Thanks Daniel, that seems to be working well. The biggest problem I have
is that I need to parse the name of the layer that had the error out of
the error->message - this works but obviously the format of the error
message could change in the future which would break my parser. I guess
there is potentially a lot of different things that could be involved in
the error so having a separate field in the error object for each of
them might be too much to ask, but a field for the layer name would
certainly be handy for me in this case :)
Cheers,
Chris
Daniel Morissette wrote:
> Chris Hodgson wrote:
>> I'm implementing a WMS proxy server using PHP mapscript. I'm fetching
>> the capabilities programmatically and storing them in a database and
>> then building a mapfile on the fly. The mapfile contains multiple
>> "connectiontype WMS" layers, and I'd like to be able to (a) determine
>> when one of the WMS client requests has failed, and (b) get the error
>> message returned for each failed layer. I'm starting to think this
>> may not be possible currently, and it seems that the code for doing
>> anything like this has been pushed back for a while [
>> http://trac.osgeo.org/mapserver/ticket/1246 ].
>> Any chance that I'm wrong and there is already a way to do this?
>> Anybody else interested in this feature? Anybody already done
>> something like this?
> Ticket 1246 is only about the *default* exception format, but using
> the wms_exceptions_format metadata you can override the default and
> request text/xml or application/vnd.ogc.se_xml exceptions (depending
> on WMS version).
> Then if an exception is received MapServer will try to read the
> exception message and pass it to msSetError() with an error code of
> MS_WMSERR (24). This does not cause a fatal error and won't stop your
> script though, the message is only stored in the error stack. In
> MapScript you should be able to read the error stack (errorObj) and
> extract the error messages.
> More about the errorObj at
> http://mapserver.org/trunk/en/mapscript/php/index.html#errorobj-class
> I think the handling of WMS exceptions could be greatly improved, but
> you may be able to get along with this basic stuff.
> Daniel
