[mapserver-users] Raster layers with partial transparency
Chris Hodgson
chodgson at refractions.net
Wed Sep 16 19:20:27 EDT 2009
Just a guess but have you tried with transparent = 0? Just wondering if
the transparent mode rendering is somehow overriding the RGBA alpha mode
rendering?
Chris
Jason Beverage wrote:
> Hi all,
> I'm serving up some raster imagery with an alpha band that contains
> partially transparent pixels using mapscript but when the image is
> rendered, the partially transparent portions (alpha between 5 and 10)
> come through completely opaque (alpha of 255). Areas that are fully
> opaque or fully transparent look fine.
> I'm using an output format with the GD/PNG renderer with a RGBA image
> mode and "transparent" set to true. I've tried using the AGG/PNG and
> GDAL/PNG renderers with the same result.
> C# code for the output format:
> map.outputformat.name <http://map.outputformat.name> = "PNG";
> map.outputformat.driver = "GD/PNG";
> map.outputformat.mimetype = "image/png";
> map.outputformat.imagemode = (int)MS_IMAGEMODE.MS_IMAGEMODE_RGBA;
> map.outputformat.extension = "png";
> map.outputformat.transparent = 1;
> Any ideas on what I'm doing wrong?
> Thanks,
> Jason
> mapserver-users at lists.osgeo.org
