[mapserver-users] Problem with WMS Request through Mapserver
Yewondwossen Assefa
yassefa at dmsolutions.ca
Fri Sep 18 16:57:18 EDT 2009
metadata name is in fact ows_exceptions_format instead of ows_exception
Yewondwossen Assefa wrote:
> Hi There,
> Maybe you could do a GetCapabilities request on the WMS server and see
> what are the types of exceptions that are supported by the server. It
> might support other exceptions than the application/vnd.ogc.se_inimage.
> if that is the case, you can set a layer level metadata called
> ows_exception to the one that is supported. Something like:
> METADATA
> "ows_exception" "supported_exception"
> END
> best regards,
> Robert Hicks wrote:
>> I am making a WMS request from a simple OpenLayers client to Mapserver
>> which is in turn calling another WMS server. My problem is, is that
>> the call from MapServer to the secondary WMS server has an extra
>> paramater tacked on: EXCEPTIONS=application/vnd.ogc.se_inimage (I saw
>> this going through Wire Shark which is a packet sniffer), and when I
>> grab the exact call, strip out that argument, the image returns fine.
>> Is there a way to specify, in the map file, that I either do not want
>> this? Note, that the request coming from OpenLayers does not have this
>> argument (I found this out via Firebug).
>> Here is a layer out of my map file:
>> LAYER
>> # name of layer
>> NAME "Infrared1995"
>> GROUP "newjerseywms"
>> # what type of data is this?
>> TYPE RASTER
>> # always returned with interface
>> STATUS ON
>> CONNECTION "http://njwebmap.state.nj.us/njorthos"
>> CONNECTIONTYPE WMS
>> METADATA
>> "wms_srs" "EPSG:4326"
>> "wms_name" "Infrared1995"
>> "wms_server_version" "1.1.1"
>> "wms_format" "image/png"
>> END
>> END
>> Thanks!
>> web http://www.hyxspace.com
>> aim hyx1138
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
