[mapserver-users] display feature name beside feature
sunny74
sb.ray at hotmail.com
Mon Sep 21 08:34:13 EDT 2009
Hi Lars,
I have added the fontset file and also the Label and other definitions at
the appropriate places but still the Labels are not being displayed for the
layer RailwayStation.
My map file now looks like this:
# Map file created from QGIS project file D:/QGIS/newwr.qgs
# Edit this file to customize for your map interface
# (Created with PyQgis MapServer Export plugin)
MAP
NAME newwr.map
# Map image size
SIZE 600 600
UNITS dd
EXTENT 67.440106 17.379867 78.390250 25.122977
FONTSET 'c:/ms4w/Apache/cgi-bin/shape/fonts.txt'
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
# Background color for the map canvas -- change as desired
IMAGECOLOR 192 192 192
IMAGEQUALITY 95
IMAGETYPE gif
OUTPUTFORMAT
NAME gif
DRIVER 'GD/GIF'
MIMETYPE 'image/gif'
#IMAGEMODE PC256
EXTENSION 'gif'
END
# Legend
LEGEND
IMAGECOLOR 255 255 255
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
END
# Web interface definition. Only the template parameter
# is required to display a map. See MapServer documentation
WEB
# Set IMAGEPATH to the path where MapServer should
# write its output.
IMAGEPATH '/tmp/'
# Set IMAGEURL to the url that points to IMAGEPATH
# as defined in your web server configuration
IMAGEURL '/tmp/'
# WMS server settings
METADATA
'wms_title' 'newwr.map'
'wms_onlineresource'
'http://my.host.com/cgi-bin/mapserv?map=wms.map&'
'wms_srs' 'EPSG:4326'
END
#Scale range at which web interface will operate
# Template and header/footer settings
# Only the template parameter is required to display a map. See
END
LAYER
NAME 'STATE'
TYPE POLYGON
DATA 'C:\ms4w\Apache\cgi-bin\Shape\STATE.shp'
LABELITEM 'STATE'
CLASSITEM 'STATE'
METADATA
'wms_title' 'STATE'
END
STATUS DEFAULT
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'STATE'
STYLE
SYMBOL 0
SIZE 2
OUTLINECOLOR 0 0 0
COLOR 255 255 127
END
END
END
LAYER
GROUP 'basic1'
NAME 'WaterBody'
TYPE POLYGON
DATA 'C:\ms4w\Apache\cgi-bin\Shape\WaterBody.shp'
METADATA
'wms_title' 'WaterBody'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'WaterBody'
MAXSCALEDENOM 2000000
MINSCALEDENOM 1500000
STYLE
SYMBOL 0
SIZE 2
OUTLINECOLOR 0 0 0
COLOR 150 123 90
END
END
END
LAYER
GROUP 'basic1'
NAME 'Rail_Buffer'
TYPE POLYGON
DATA 'C:\ms4w\Apache\cgi-bin\Shape\Rail_Buffer.shp'
METADATA
'wms_title' 'Rail_Buffer'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'Rail_Buffer'
STYLE
SYMBOL 0
SIZE 2
OUTLINECOLOR 0 0 0
COLOR 117 232 255
END
END
END
LAYER
GROUP 'basic1'
NAME 'Roads'
TYPE LINE
DATA 'C:\ms4w\Apache\cgi-bin\Shape\Roads.shp'
METADATA
'wms_title' 'Roads'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'Roads'
STYLE
SYMBOL 0
SIZE 2
OUTLINECOLOR 45 220 182
COLOR 0 0 0
END
END
END
LAYER
GROUP 'basic2'
NAME 'Diversions'
TYPE LINE
DATA 'C:\ms4w\Apache\cgi-bin\Shape\Diversions.shp'
METADATA
'wms_title' 'Diversions'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'Diversions'
MAXSCALEDENOM 1500000
MINSCALEDENOM 1000000
STYLE
SYMBOL 0
SIZE 2
OUTLINECOLOR 144 50 207
COLOR 0 0 0
END
END
END
LAYER
GROUP 'basic2'
NAME 'Rail_Side_Line'
TYPE LINE
DATA 'C:\ms4w\Apache\cgi-bin\Shape\Rail_Side_Line.shp'
METADATA
'wms_title' 'Rail_Side_Line'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
STYLE
SYMBOL 0
SIZE 2
OUTLINECOLOR 170 115 90
COLOR 0 0 0
END
END
END
LAYER
GROUP 'basic'
NAME 'RailwayLine'
TYPE LINE
DATA 'C:\ms4w\Apache\cgi-bin\Shape\RailwayLine.shp'
METADATA
'wms_title' 'RailwayLine'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'RailwayLine'
STYLE
SYMBOL 0
SIZE 2
OUTLINECOLOR 255 0 0
COLOR 255 0 0
END
END
END
LAYER
GROUP 'basic2'
NAME 'LANDMARKS'
TYPE POINT
DATA 'C:\ms4w\Apache\cgi-bin\Shape\LANDMARKS.shp'
METADATA
'wms_title' 'LANDMARKS'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'LANDMARKS'
STYLE
SYMBOL 'CIRCLE'
SIZE 8
OUTLINECOLOR 0 0 0
COLOR 229 210 191
END
END
END
LAYER
GROUP 'basic'
NAME 'RailwayStations'
TYPE POINT
DATA 'C:\ms4w\Apache\cgi-bin\Shape\RailwayStations.shp'
CLASSITEM 'S_NAME'
LABELITEM 'S_NAME'
METADATA
'wms_title' 'RailwayStations'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
STYLE
SYMBOL 'CIRCLE'
SIZE 8
OUTLINECOLOR 0 0 0
COLOR 255 0 0
END
LABEL
COLOR 132 31 31
SHADOWCOLOR 218 218 218
SHADOWSIZE 2 2
TYPE TRUETYPE
FONT arial-bold
SIZE 12
ANTIALIAS TRUE
POSITION CL
PARTIALS FALSE
MINDISTANCE 300
BUFFER 4
END # end of label
END
END
LAYER
GROUP 'basic3'
NAME 'LC_Gate'
TYPE POINT
DATA 'C:\ms4w\Apache\cgi-bin\Shape\LC_Gate.shp'
METADATA
'wms_title' 'LC_Gate'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'LC_Gate'
MAXSCALEDENOM 1000000
MINSCALEDENOM 500000
STYLE
SYMBOL 'CIRCLE'
SIZE 8
OUTLINECOLOR 0 0 0
COLOR 15 155 200
END
END
END
LAYER
GROUP 'basic3'
NAME 'Bridges_Minor'
TYPE POINT
DATA 'C:\ms4w\Apache\cgi-bin\Shape\Bridges_Minor.shp'
METADATA
'wms_title' 'Bridges_Minor'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
STYLE
SYMBOL 'CIRCLE'
SIZE 2
OUTLINECOLOR 0 0 0
COLOR 43 253 114
END
END
END
LAYER
GROUP 'basic3'
NAME 'Bridge_Major'
TYPE POINT
DATA 'C:\ms4w\Apache\cgi-bin\Shape\Bridge_Major.shp'
METADATA
'wms_title' 'Bridge_Major'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'Bridge_Major'
STYLE
SYMBOL 'CIRCLE'
SIZE 2
OUTLINECOLOR 0 0 0
COLOR 97 136 146
END
END
END
#Circle symbol
SYMBOL
NAME 'CIRCLE'
TYPE ellipse
FILLED true
POINTS
1 1
END
END
END
My Fontset file is fonts.txt and it is located in the same folder as the map
file.
It contains the following:
arial C:/WINDOWS/Fonts/arial.ttf
arial-bold C:/WINDOWS/Fonts/arialbd.ttf
So where is the problem?
Where am I going wrong?
Thanks for your reply.
sunny.
Lars Lingner-2 wrote:
> sunny74 schrieb:
>> Hi Michael,
>> I had gone thru' the links you have given before making this post.But I
>> am
>> having the problems given in the link below:
>> http://n2.nabble.com/font-error-while-trying-to-show-Label-on-map-td3654455.html#a3654455
>> When using truetype I get the error probably bec' I am not able to
>> specify
>> the fontset file.
>> So I need to know the following:
>> 1) What kind of file is the fontset file?I think it is a text file
> its just a textfile, yes
>> 2) Where do I keep the fontset file - in the same folder as the map file
>> or
>> in different folder.If different folder how do I specify the path in the
>> map
>> file.
> as you wish. You have to tell MapServer the place with the keywortd
> FONTSET.
>> 3) Where do I keep the fonts? Is it okay if I keep it in the Windows Font
>> Folder i.e C:/Windows/Fonts
> yes, you can keep it there. MapServer needs read permissions to the
> fonts. In the fonset file you can define the path.
>> 4)How do I specify the path of the fonts in the fontset file?
> /path/to/fonts/font.ttf
> Please have a look at
> http://mapserver.org/mapfile/map.html
> and
> http://mapserver.org/mapfile/fontset.html
> Lars
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/display-feature-name-beside-feature-tp3668538p3684929.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
