[mapserver-users] Creating maps from external gml files
Lid Sjur Ringheim
sjur.ringheim.lid at imr.no
Mon Sep 21 07:47:03 EDT 2009
I'm developing an application that creates gml files and displays them in OpenLayers. This creates a small problem when the amount of point data becomes to large, so I was thinking of using a wms server to create a single layer based on the data.
The problem I'm now facing is that I can't be sure that I can run the application (developed in Java as a webservice) on the same server that we are running Mapserver so I can't base the generation of the wms service on local data. I have been trying to find out if it's possible to use Mapserver to generate images based on input from the user but I can't seem to find any information on this.
Do any of you know if it is possible to generate images based on input from the user (in form of a gml file or anything else). I have looked at the Web Map Context but that seems to only work if I already have a wms server to output data.
If this isn't possible to do in Mapserver do anyone know if there is another way to do this?
Kind regards,
Sjur Ringheim Lid
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090921/a3a59817/attachment.html
