[mapserver-users] Mapscript taking too long on my production
server
Tamas Szekeres
szekerest at gmail.com
Mon Sep 21 10:02:12 EDT 2009
Nelson,
Depending on your MapSever version you could set up the debug options in
your mapfile in order to see the timings when the layers are drawn.
like:
CONFIG "MS_ERRORFILE" "/ms4w/tmp/ms_error.txt"
DEBUG 5
For more info about the debugging options see:
http://mapserver.org/mapfile/map.html
http://mapserver.org/mapfile/layer.html
Best regards,
Tamas
2009/9/21 Nelson Correia <nelsonwc7 at hotmail.com>
> Hi all,
> I'm doing an application in C# that uses mapscript to generate images. The
> features come from a postgis database.
> On my development machine all goes well and the image is always generated
> in less than 1 second. When I deployed the application to my two production
> servers (both powerfull than my dev machine), I noticed a very strange
> behavior: it takes +-20 seconds to generate the same image. Doing some debug
> on what's happening, I realized that was the call to mapObj.draw() method
> that was taking all that time.
> Thinking it could be a database related problem, (note that I'm using a
> local database) I've inspected the server logs and saw that the query only
> arrived at the database after that 20 seconds. So, the time is being taken
> in the draw, but before the database call.
> Anyone have a clue on what could be happening?
> Thanks,
> Nelson
> What can you do with the new Windows Live? Find out<http://www.microsoft.com/windows/windowslive/default.aspx>
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090921/034d0d61/attachment.html
