[mapserver-users] SV: display feature name beside feature
sunny74
sb.ray at hotmail.com
Wed Sep 23 14:13:05 EDT 2009
Hi Lars,Steve
Thanks for your suggestions.
I am now able to see the Label but not not at the base scale at which the
page loads for the first time.
I am able to see a few at the next zoomin level, followed by next set of
labels at a still higher zoomin level and so on.
What are the label attributes that make this happen?
What shud I do if I need to see all of the Labels at at single scale i.e
zoomin level.
Thanks a lot for your support.
Lars Westerlind wrote:
> Try removing "CLASSITEM" from the layer with the label. As you have no
> expression, I think the class does not match. I also expect a warning for
> this in the log file.
> /Lars
> -----Ursprungligt meddelande-----
> Från: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] För sunny74
> Skickat: 23 September 2009 06:58
> Till: mapserver-users at lists.osgeo.org
> Ämne: Re: [mapserver-users] display feature name beside feature
> Hi Steve,
> Thanks for your reply.
> Regarding the railway points I was able to see the points before doing all
> this.
> I did all this just to see the Labels i.e names of the railway stations
> beside the points
> But I am not able to see this.
> Can u tell me where the problem is?
> What am I doing wrong?
> Thanks again.
> Steve Lime wrote:
>> And you can see the railway points?
>>>>> On 9/21/2009 at 7:34 AM, in message
>>>>> <1253536453758-3684929.post at n2.nabble.com>,
>> sunny74 <sb.ray at hotmail.com> wrote:
>>> Hi Lars,
>>> I have added the fontset file and also the Label and other definitions
>>> at
>>> the appropriate places but still the Labels are not being displayed for
>>> the
>>> layer RailwayStation.
>>> My map file now looks like this:
>>> # Map file created from QGIS project file D:/QGIS/newwr.qgs
>>> # Edit this file to customize for your map interface
>>> # (Created with PyQgis MapServer Export plugin)
>>> MAP
>>> NAME newwr.map
>>> # Map image size
>>> SIZE 600 600
>>> UNITS dd
>>> EXTENT 67.440106 17.379867 78.390250 25.122977
>>> FONTSET 'c:/ms4w/Apache/cgi-bin/shape/fonts.txt'
>>> PROJECTION
>>> 'proj=longlat'
>>> 'ellps=WGS84'
>>> 'datum=WGS84'
>>> 'no_defs'
>>> END
>>> # Background color for the map canvas -- change as desired
>>> IMAGECOLOR 192 192 192
>>> IMAGEQUALITY 95
>>> IMAGETYPE gif
>>> OUTPUTFORMAT
>>> NAME gif
>>> DRIVER 'GD/GIF'
>>> MIMETYPE 'image/gif'
>>> #IMAGEMODE PC256
>>> EXTENSION 'gif'
>>> END
>>> # Legend
>>> LEGEND
>>> IMAGECOLOR 255 255 255
>>> STATUS ON
>>> KEYSIZE 18 12
>>> LABEL
>>> TYPE BITMAP
>>> SIZE MEDIUM
>>> COLOR 0 0 89
>>> END
>>> END
>>> # Web interface definition. Only the template parameter
>>> # is required to display a map. See MapServer documentation
>>> WEB
>>> # Set IMAGEPATH to the path where MapServer should
>>> # write its output.
>>> IMAGEPATH '/tmp/'
>>> # Set IMAGEURL to the url that points to IMAGEPATH
>>> # as defined in your web server configuration
>>> IMAGEURL '/tmp/'
>>> # WMS server settings
>>> METADATA
>>> 'wms_title' 'newwr.map'
>>> 'wms_onlineresource'
>>> 'http://my.host.com/cgi-bin/mapserv?map=wms.map&'
>>> 'wms_srs' 'EPSG:4326'
>>> END
>>> #Scale range at which web interface will operate
>>> # Template and header/footer settings
>>> # Only the template parameter is required to display a map. See
>>> END
>>> LAYER
>>> NAME 'STATE'
>>> TYPE POLYGON
>>> DATA 'C:\ms4w\Apache\cgi-bin\Shape\STATE.shp'
>>> LABELITEM 'STATE'
>>> CLASSITEM 'STATE'
>>> METADATA
>>> 'wms_title' 'STATE'
>>> END
>>> STATUS DEFAULT
>>> TRANSPARENCY 100
>>> PROJECTION
>>> 'proj=longlat'
>>> 'ellps=WGS84'
>>> 'datum=WGS84'
>>> 'no_defs'
>>> END
>>> CLASS
>>> NAME 'STATE'
>>> STYLE
>>> SYMBOL 0
>>> SIZE 2
>>> OUTLINECOLOR 0 0 0
>>> COLOR 255 255 127
>>> END
>>> END
>>> END
>>> LAYER
>>> GROUP 'basic1'
>>> NAME 'WaterBody'
>>> TYPE POLYGON
>>> DATA 'C:\ms4w\Apache\cgi-bin\Shape\WaterBody.shp'
>>> METADATA
>>> 'wms_title' 'WaterBody'
>>> END
>>> STATUS OFF
>>> TRANSPARENCY 100
>>> PROJECTION
>>> 'proj=longlat'
>>> 'ellps=WGS84'
>>> 'datum=WGS84'
>>> 'no_defs'
>>> END
>>> CLASS
>>> NAME 'WaterBody'
>>> MAXSCALEDENOM 2000000
>>> MINSCALEDENOM 1500000
>>> STYLE
>>> SYMBOL 0
>>> SIZE 2
>>> OUTLINECOLOR 0 0 0
>>> COLOR 150 123 90
>>> END
>>> END
>>> END
>>> LAYER
>>> GROUP 'basic1'
>>> NAME 'Rail_Buffer'
>>> TYPE POLYGON
>>> DATA 'C:\ms4w\Apache\cgi-bin\Shape\Rail_Buffer.shp'
>>> METADATA
>>> 'wms_title' 'Rail_Buffer'
>>> END
>>> STATUS OFF
>>> TRANSPARENCY 100
>>> PROJECTION
>>> 'proj=longlat'
>>> 'ellps=WGS84'
>>> 'datum=WGS84'
>>> 'no_defs'
>>> END
>>> CLASS
>>> NAME 'Rail_Buffer'
>>> STYLE
>>> SYMBOL 0
>>> SIZE 2
>>> OUTLINECOLOR 0 0 0
>>> COLOR 117 232 255
>>> END
>>> END
>>> END
>>> LAYER
>>> GROUP 'basic1'
>>> NAME 'Roads'
>>> TYPE LINE
>>> DATA 'C:\ms4w\Apache\cgi-bin\Shape\Roads.shp'
>>> METADATA
>>> 'wms_title' 'Roads'
>>> END
>>> STATUS OFF
>>> TRANSPARENCY 100
>>> PROJECTION
>>> 'proj=longlat'
>>> 'ellps=WGS84'
>>> 'datum=WGS84'
>>> 'no_defs'
>>> END
>>> CLASS
>>> NAME 'Roads'
>>> STYLE
>>> SYMBOL 0
>>> SIZE 2
>>> OUTLINECOLOR 45 220 182
>>> COLOR 0 0 0
>>> END
>>> END
>>> END
>>> LAYER
>>> GROUP 'basic2'
>>> NAME 'Diversions'
>>> TYPE LINE
>>> DATA 'C:\ms4w\Apache\cgi-bin\Shape\Diversions.shp'
>>> METADATA
>>> 'wms_title' 'Diversions'
>>> END
>>> STATUS OFF
>>> TRANSPARENCY 100
>>> PROJECTION
>>> 'proj=longlat'
>>> 'ellps=WGS84'
>>> 'datum=WGS84'
>>> 'no_defs'
>>> END
>>> CLASS
>>> NAME 'Diversions'
>>> MAXSCALEDENOM 1500000
>>> MINSCALEDENOM 1000000
>>> STYLE
>>> SYMBOL 0
>>> SIZE 2
>>> OUTLINECOLOR 144 50 207
>>> COLOR 0 0 0
>>> END
>>> END
>>> END
>>> LAYER
>>> GROUP 'basic2'
>>> NAME 'Rail_Side_Line'
>>> TYPE LINE
>>> DATA 'C:\ms4w\Apache\cgi-bin\Shape\Rail_Side_Line.shp'
>>> METADATA
>>> 'wms_title' 'Rail_Side_Line'
>>> END
>>> STATUS OFF
>>> TRANSPARENCY 100
>>> PROJECTION
>>> 'proj=longlat'
>>> 'ellps=WGS84'
>>> 'datum=WGS84'
>>> 'no_defs'
>>> END
>>> CLASS
>>> STYLE
>>> SYMBOL 0
>>> SIZE 2
>>> OUTLINECOLOR 170 115 90
>>> COLOR 0 0 0
>>> END
>>> END
>>> END
>>> LAYER
>>> GROUP 'basic'
>>> NAME 'RailwayLine'
>>> TYPE LINE
>>> DATA 'C:\ms4w\Apache\cgi-bin\Shape\RailwayLine.shp'
>>> METADATA
>>> 'wms_title' 'RailwayLine'
>>> END
>>> STATUS OFF
>>> TRANSPARENCY 100
>>> PROJECTION
>>> 'proj=longlat'
>>> 'ellps=WGS84'
>>> 'datum=WGS84'
>>> 'no_defs'
>>> END
>>> CLASS
>>> NAME 'RailwayLine'
>>> STYLE
>>> SYMBOL 0
>>> SIZE 2
>>> OUTLINECOLOR 255 0 0
>>> COLOR 255 0 0
>>> END
>>> END
>>> END
>>> LAYER
>>> GROUP 'basic2'
>>> NAME 'LANDMARKS'
>>> TYPE POINT
>>> DATA 'C:\ms4w\Apache\cgi-bin\Shape\LANDMARKS.shp'
>>> METADATA
>>> 'wms_title' 'LANDMARKS'
>>> END
>>> STATUS OFF
>>> TRANSPARENCY 100
>>> PROJECTION
>>> 'proj=longlat'
>>> 'ellps=WGS84'
>>> 'datum=WGS84'
>>> 'no_defs'
>>> END
>>> CLASS
>>> NAME 'LANDMARKS'
>>> STYLE
>>> SYMBOL 'CIRCLE'
>>> SIZE 8
>>> OUTLINECOLOR 0 0 0
>>> COLOR 229 210 191
>>> END
>>> END
>>> END
>>> LAYER
>>> GROUP 'basic'
>>> NAME 'RailwayStations'
>>> TYPE POINT
>>> DATA 'C:\ms4w\Apache\cgi-bin\Shape\RailwayStations.shp'
>>> CLASSITEM 'S_NAME'
>>> LABELITEM 'S_NAME'
>>> METADATA
>>> 'wms_title' 'RailwayStations'
>>> END
>>> STATUS OFF
>>> TRANSPARENCY 100
>>> PROJECTION
>>> 'proj=longlat'
>>> 'ellps=WGS84'
>>> 'datum=WGS84'
>>> 'no_defs'
>>> END
>>> CLASS
>>> STYLE
>>> SYMBOL 'CIRCLE'
>>> SIZE 8
>>> OUTLINECOLOR 0 0 0
>>> COLOR 255 0 0
>>> END
>>> LABEL
>>> COLOR 132 31 31
>>> SHADOWCOLOR 218 218 218
>>> SHADOWSIZE 2 2
>>> TYPE TRUETYPE
>>> FONT arial-bold
>>> SIZE 12
>>> ANTIALIAS TRUE
>>> POSITION CL
>>> PARTIALS FALSE
>>> MINDISTANCE 300
>>> BUFFER 4
>>> END # end of label
>>> END
>>> END
>>> LAYER
>>> GROUP 'basic3'
>>> NAME 'LC_Gate'
>>> TYPE POINT
>>> DATA 'C:\ms4w\Apache\cgi-bin\Shape\LC_Gate.shp'
>>> METADATA
>>> 'wms_title' 'LC_Gate'
>>> END
>>> STATUS OFF
>>> TRANSPARENCY 100
>>> PROJECTION
>>> 'proj=longlat'
>>> 'ellps=WGS84'
>>> 'datum=WGS84'
>>> 'no_defs'
>>> END
>>> CLASS
>>> NAME 'LC_Gate'
>>> MAXSCALEDENOM 1000000
>>> MINSCALEDENOM 500000
>>> STYLE
>>> SYMBOL 'CIRCLE'
>>> SIZE 8
>>> OUTLINECOLOR 0 0 0
>>> COLOR 15 155 200
>>> END
>>> END
>>> END
>>> LAYER
>>> GROUP 'basic3'
>>> NAME 'Bridges_Minor'
>>> TYPE POINT
>>> DATA 'C:\ms4w\Apache\cgi-bin\Shape\Bridges_Minor.shp'
>>> METADATA
>>> 'wms_title' 'Bridges_Minor'
>>> END
>>> STATUS OFF
>>> TRANSPARENCY 100
>>> PROJECTION
>>> 'proj=longlat'
>>> 'ellps=WGS84'
>>> 'datum=WGS84'
>>> 'no_defs'
>>> END
>>> CLASS
>>> STYLE
>>> SYMBOL 'CIRCLE'
>>> SIZE 2
>>> OUTLINECOLOR 0 0 0
>>> COLOR 43 253 114
>>> END
>>> END
>>> END
>>> LAYER
>>> GROUP 'basic3'
>>> NAME 'Bridge_Major'
>>> TYPE POINT
>>> DATA 'C:\ms4w\Apache\cgi-bin\Shape\Bridge_Major.shp'
>>> METADATA
>>> 'wms_title' 'Bridge_Major'
>>> END
>>> STATUS OFF
>>> TRANSPARENCY 100
>>> PROJECTION
>>> 'proj=longlat'
>>> 'ellps=WGS84'
>>> 'datum=WGS84'
>>> 'no_defs'
>>> END
>>> CLASS
>>> NAME 'Bridge_Major'
>>> STYLE
>>> SYMBOL 'CIRCLE'
>>> SIZE 2
>>> OUTLINECOLOR 0 0 0
>>> COLOR 97 136 146
>>> END
>>> END
>>> END
>>> #Circle symbol
>>> SYMBOL
>>> NAME 'CIRCLE'
>>> TYPE ellipse
>>> FILLED true
>>> POINTS
>>> 1 1
>>> END
>>> END
>>> END
>>> My Fontset file is fonts.txt and it is located in the same folder as the
>>> map
>>> file.
>>> It contains the following:
>>> arial C:/WINDOWS/Fonts/arial.ttf
>>> arial-bold C:/WINDOWS/Fonts/arialbd.ttf
>>> So where is the problem?
>>> Where am I going wrong?
>>> sunny.
>>> Lars Lingner-2 wrote:
>>>> sunny74 schrieb:
>>>>> Hi Michael,
>>>>> I had gone thru' the links you have given before making this post.But
>>>>> I
>>>>> am
>>>>> having the problems given in the link below:
>>> http://n2.nabble.com/font-error-while-trying-to-show-Label-on-map-td3654455.html#a3654
>>> 455
>>>>> When using truetype I get the error probably bec' I am not able to
>>>>> specify
>>>>> the fontset file.
>>>>> So I need to know the following:
>>>>> 1) What kind of file is the fontset file?I think it is a text file
>>>> its just a textfile, yes
>>>>> 2) Where do I keep the fontset file - in the same folder as the map
>>>>> file
>>>>> or
>>>>> in different folder.If different folder how do I specify the path in
>>>>> the
>>>>> map
>>>>> file.
>>>> as you wish. You have to tell MapServer the place with the keywortd
>>>> FONTSET.
>>>>> 3) Where do I keep the fonts? Is it okay if I keep it in the Windows
>>>>> Font
>>>>> Folder i.e C:/Windows/Fonts
>>>> yes, you can keep it there. MapServer needs read permissions to the
>>>> fonts. In the fonset file you can define the path.
>>>>> 4)How do I specify the path of the fonts in the fontset file?
>>>> /path/to/fonts/font.ttf
>>>> Please have a look at
>>>> http://mapserver.org/mapfile/map.html
>>>> and
>>>> http://mapserver.org/mapfile/fontset.html
>>>> Lars
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> http://n2.nabble.com/display-feature-name-beside-feature-tp3668538p3697539.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
View this message in context: http://n2.nabble.com/display-feature-name-beside-feature-tp3668538p3701418.html
