AW: [mapserver-users] Invalid format for theEXCEPTIONparameter
Robert Sanson SansonR at asurequality.com
Wed Sep 23 16:56:34 EDT 2009
Hi Arnd and list
Here is a response from an ESRI agent in New Zealand:
"The issue you are reporting has been logged as a bug.  #NIM045493  ArcMap GETREQUEST is not compliant with the 1.3.0 version of the WMS standard. We have added this incident to the bug and you will be the 5th user tied to it.
The bug has been assigned to an ESRI Developer to be worked on but a timeframe for a fix has not yet been specified.  There is no workaround listed for the bug at this time.  We apologize for any inconvenience this has caused and we hope to have this fixed in a future release."
regards,
Robert
>>> "Arnd Wippermann" <arnd.wippermann at web.de> 24/09/2009 3:48 a.m. >>>
in ArcMap 9.3 it's possible to change from default version for the WMS request to other versions.
Arnd
Von: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag von Robert Sanson
Gesendet: Mittwoch, 23. September 2009 02:49
An: Yewondwossen Assefa
Cc: mapserver-users at lists.osgeo.org
Betreff: Re: [mapserver-users] Invalid format for the EXCEPTIONparameter
Hi Assefa
Unfortunately not - it seems to be hardcoded in. Can I get Mapserver to only offer WMS version 1.1.1?
Thanks,
Robert
>>> Yewondwossen Assefa <yassefa at dmsolutions.ca> 23/09/2009 12:48 p.m. >>>
Hi There,
Valid EXCEPTIONS values for wms 1.3.0 are INIMAGE, BLANK, XML.
application/vnd.ogc.se_XML was used for previous versions. Do you have
any control on this parameter from ArcMap/ArcCatalog ?
regards
Robert Sanson wrote:
> I have a 5.4.2 version of Mapserver (MS4W) configured for WMS access.
> OpenLayers is accessing it fine, however, ArcMap / ArcCatalog v 9.3 is
> giving me an Error message:
> WMS service exceptions:-Service Error Code:InvalidFormat
> Service Error Description: msWMSLoadGetMapParams(): WMS server error.
> Invalid format for the EXCEPTION parameter.
> Looking in the Apache access.log file I see:
> "GET
> /cgi-bin/mapserv.exe?map=/ms4w/apps/service/nztm.map&VERSION=1.3.0&REQUEST=GetMap&CRS=EPSG:2193&BBOX=773500,4615000,2602100,5973130.71761735
> &WIDTH=82&HEIGHT=111&LAYERS=crs_roads,crs_address,centroids,main_gates,main_homesteads,stockyards,dairysheds,synlait,apiaries,copyright
> &STYLES=,,,,,,,,,&EXCEPTIONS=application/vnd.ogc.se_XML&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE
> HTTP/1.0"
> In my various layer Metadata I have the following:
>   METADATA
>    "ows_title"    "apiaries"
>    "ows_abstract"    "These are the registered apiaries from the Apiary DB"
>    "wms_srs"   "EPSG:2193"
>    "wms_opaque"    "0"
>    "wms_group_title" "API"
>    "wms_group_abstract" "Apiaries"
>    "ows_extent" "773500 4615000 2602100 6324500"
>    "wms_dataurl_format" "text/html"
>    "gml_include_items" "all"
>    "wms_exceptions_format" "application/vnd.ogc.se_xml"
>   END
> Many thanks,
> Robert Sanson
The contents of this email are confidential to AsureQuality. If you have received this communication in error please notify the sender immediately and delete the message and any attachments. The opinions expressed in this email are not necessarily those of AsureQuality. This message has been scanned for known viruses before delivery. AsureQuality supports the Unsolicited Electronic Messages Act 2007. If you do not wish to receive similar communications in future, please notify the sender of this message.
This message has been scanned for malware by SurfControl plc. www.surfcontrol.com ( http://www.surfcontrol.com/ )
Click here ( https://www.mailcontrol.com/sr/wQw0zmjPoHdJTZGyOCrrhg== ) to report this email as spam.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090924/a4c3fbc6/attachment-0001.html
