[mapserver-users] Does tilemode actually work?
Sven Geggus
lists at fuchsschwanzdomain.de
Thu Sep 24 09:54:01 EDT 2009
Starting from a mapserver setup which works fine in WMS Mode I tried to
access the same machine with mode=tile.
Unfortunately it looks like something is wrong with the zoom factor.
Position seems to be fairly correct however:
Just compare the following URLs:
http://a.tile.openstreetmap.org/14/8574/5625.png
http://geo.gegg.us/lv-bw.cgi?LAYERS=DVDOP2&mode=tile&tilemode=gmap&tile=8574+5625+14
The first URL is from the Openstreetmap Tileserver, the second is just the
image of a public WMS-Server reprojected from GK2 (epsg:31467).
Mapfile looks like this:
--cut--
MAP
NAME lv-bw
STATUS ON
UNITS METERS
WEB
METADATA
"wms_title" "Svens lv-bw Proxyserver"
"wms_onlineresource" "http://geo.gegg.us/lv-bw.cgi?"
"wms_srs" "EPSG:4326"
END
END
PROJECTION "init=epsg:31467" END
EXTENT 3340000 5230000 3615000 5550000
WEB
IMAGEPATH "/tmp/"
END
LAYER
NAME "DVDOP2"
METADATA
"wms_title" "lv-bw.de Data" ##required
END
TYPE RASTER
STATUS ON
CONNECTION "http://www.lv-bw.de/rdsaccess/default.aspx?ServiceName=geodata31467&reaspect=false&"
CONNECTIONTYPE WMS
METADATA
"wms_srs" "EPSG:31467"
"wms_server_version" "1.1.1"
"wms_name" "DOP2"
# Non Standard :(
"wms_format" "png"
END
END
END
--cut--
The mapserver Version in use is 5.4.2 from Debian GNU/Linux:
$ /usr/lib/cgi-bin/mapserv -v
MapServer version 5.4.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Regards
Sven
"Whenever there is a conflict between human rights and property
rights, human rights must prevail." (Abraham Lincoln)
/me is giggls at ircnet, http://sven.gegg.us/ on the Web
