[mapserver-users] Scale Bar Size Issue
PatB
pbarnhart at gis-services.com
Fri Sep 25 00:04:27 EDT 2009
I'm using the code below to request a scalebar from mapserver. My
understanding of the documentation is that the size parameter sets the size
of the scalebar itself not including the text, border, etc but that's not
what I'm getting back. The url below returns an image that is 600 x 153
(I'm requesting 600 x 75) when it should be more like 750 x 153 to account
for the surrounding stuff. The height works as expected and the
units/distances look right, the width of the scalebar itself is the issue.
This is for a print app, the output res is 300dpi so by setting the width to
600 I was hoping to print a 2 inch wide scale bar with four 1/2" intervals.
This seems like it would be a common task but I've been digging though the
forum for hours without success. A little help? I'm using MS version 5.4.2
mapserv.exe?MAP=C:/ms4w/tmp/maps/mp.map&mode=scalebar&mapext=-8798233+4184184+-8793280+4188502&mapsize=11700+10200&map.scalebar=units+feet+size+600+75+intervals+4+label+size+40+end
and my map file goes something like:
MAP
UNITS meters
SCALEBAR
STYLE 0
IMAGECOLOR 255 255 255
LABEL
TYPE TRUETYPE
FONT "tahoma"
SIZE 40
COLOR 0 114 255
END
SIZE 600 75
COLOR 235 235 235
BACKGROUNDCOLOR 0 114 255
OUTLINECOLOR 0 0 0
UNITS meters
INTERVALS 4
STATUS on
TRANSPARENT on
END
Thanks - and yes, the map size is friggin huge.
View this message in context: http://n2.nabble.com/Scale-Bar-Size-Issue-tp3710334p3710334.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
