[mapserver-users] MapServer dynamic map creation - Is this
possible?
Daniel Walton
dgwalton at gmail.com
Mon Sep 28 12:27:13 EDT 2009
Frank,
Thanks for your very concrete and helpful response! We're creating images
that are chipped from infrared imagery using wildfire perimeter shapes. Thus
each image will be an individual layer. I am aware that 40MB is small
compared to world maps, but I wanted to know what the scalability of
MapServer would be, and if, given that potentially hundreds of server
instances per day may be created, the whole thing might grind to a halt.
What kind of disk, CPU, memory, and bandwidth requirements would you expect
such a service to require (back of the napkin calculation)?
Thanks again,
Dan
On Mon, Sep 28, 2009 at 11:11 AM, Frank Warmerdam <warmerdam at pobox.com>wrote:
> Dan Walton wrote:
>> I am new to WMS, so bear with my ignorance please.
>> I have a service that processes imagery and outputs large TIFF + World
>> file
>> images (5-40 MB), and some shapefiles. Currently these images have no
> Dan,
> Note that 5-40MB files are normally considered small in this domain.
> pyramid or tiling. I would like to further make the images web map
>> friendly
>> and my thought is that WMS and MapServer is the way to go. We will likely
>> be
>> creating dozens or perhaps hundreds of these images per day. This needs to
>> run on Windows alongside or within IIS.
>> So I have a volley of questions for anyone who might have answers. Feel
>> free
>> to skip any:
>> 1. Can MapServer even do this, that is, host several large images and
>> allow
>> new ones to be added on the fly via the api?
> Yes, this is possible. One question is whether the images are intended
> to be treated as a mosaic or as distinct, individually addressable layers.
> If they are to be a mosaic, then you want to read up on tileindexes which
> allow you to treat a set of images as a single layer - a mosaic. Then your
> task boils down to creating a static mapfile, and dynamically adding files
> to
> the tileindex as they are created.
> If each is a distinctly addressable product then they should each either
> have an associated layer in a mapfile or you need a distinct map for each
> image.
> I will say it is not prudent to have hundreds of layers in a map - it
> becomes
> quite cumbersome, so I think it would be better to treat each image as a
> distinct WMS service with it's own mapfile (possibly generated on the fly
> from a database record).
> 2. Can each image be a map layer or does each image need its own mapserver
>> instance?
> As above, either is possible.
> 3. Does the OSGeo4W include utilities to tile and pyramid the images or do
>> I
>> have to arrange for that myself?
> OSGeo4W's gdal package includes the required tools. In particular to take
> a TIFF image ("in.tif") and convert it to an optimized form with internal
> tiling and overviews ("out.tif") you would do something like:
> gdal_translate -co TILED=YES in.tif out.tif
> gdaladdo out.tif 2 4 8 16 32 64
> OSGeo4W is setup primarily for Apache, so to use it with IIS there
> will be some manual fiddling you will need to do yourself. However,
> people do it, so it is doable.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush | Geospatial Programmer for Rent
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090928/b1dd4835/attachment.html
