[mapserver-users] Query functions with Oracle Spatial
Daiane Azevedo de Fraga daiane.a.fraga at gmail.com
Mon Apr 5 12:33:10 EDT 2010
Hello!
I tried to execute a query function through an interface. Appeared in the
logfile:
[Mon Apr 05 11:09:19 2010] msOracleSpatialLayerGetShape .621000 ():
OracleSpatial error. Error parsing OracleSpatial DATA is variable query. To
execute query functions you need to define one unique column [USING UNIQUE
<# column>]
I added the ID column, and now appears in the logfile:
[Mon Apr 05 11:11:47 2010] .358000 msOracleSpatialLayerGetShape ():
OracleSpatial error. Error: ORA-00932: inconsistent datatypes: expected %s
returned %s. Query statement: SELECT ID, NBLOCK, SECTOR, BLOCK, ORIGIN,
TYPE, NAME, SUPERCOURT, COURTS, OBSERVATION, AREA, REASON, DATA, REGISTRATION,
SE_ANNO_CAD_DATA, SHAPE FROM LOTS WHERE ID = 43,192. Check your statement
date.
 What can it be? It worked in some cases. The columns are apparently
right...
There may be some incompatibility factor?
Thanks!
Daiane
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100405/47940429/attachment.html
